19's on stock suspension or not
Old Aug 10, 2002 | 05:59 AM
MAXRAY's Avatar
will it look stupid to have 19's on stock suspension? i'm concerned w/ rubbing. i want to get 245/35/19's on 19 x 8.5 rims w/ 35 offset. don't know if using H&R springs will make them rub or not.
also, for people w/ H&R springs...how's the ride quality from stock? in terms of smoothness, stiffness, etc. thanks.
Old Aug 10, 2002 | 07:43 AM
asu174's Avatar
Clay Aiken has fancy genitals
Re: 19's on stock suspension or not
That would look terrible. H&Rs shouldn't rub, although your wheel is very wide. talk to cobymoby and kloogy.
Old Aug 10, 2002 | 08:45 AM
zman187's Avatar
you would be a true 4x4
Old Aug 10, 2002 | 01:48 PM
Donkey®'s Avatar
wat
If you are gonna do something, might as well do it right...put some springs on as well. You don't want a monster truck.
Old Aug 10, 2002 | 02:24 PM
johnsmax's Avatar
NO, it will look killer. Dont listen to the haters, stock and 19s will give u a good ride. Its not like we are going to take our maxs to the track.
Old Aug 10, 2002 | 03:50 PM
MAXRAY's Avatar
i'm still very new, i've had my 02 SE for only 2 weeks. looking at the car again, looks as i really need to drop the front of the car. has anyone put H&R springs ONLY on the front? will that work w/ 19x8.5 +35offset and 245/35/19's? any pics? still debating.
Old Aug 10, 2002 | 04:13 PM
johnsmax's Avatar
ok since u wanna get techincal. My 18x8s have a 39 or more offset and u can lower it pretty much as low as u like. But with a 19x8.5 it will basically already be .25" wider than my setup for either side and with a 35 offset it will mean that the wheels will stick out more than mine to the outer fenders. In other words, assuming ur wheels/tires fit, it will look much better/meaner than my set-up. My was recommended from tire-rack, they always are on the safer side. Now, if u lower that thing, it might create a rubbing problem but then again it might not, because ur set-up will be .25" plus 39-35=4mm, which equals a total of .35"?? closer to the fenders. It will look very good, because if u are in SoCal u can come to see my car and i really wish my wheels come out a tenny tiny bit more. But i cant complain. Just ask the guys who install the wheels or springs to tell u if they rub or not. But since i dont care much about lowering, the 245/35/19s will look nice even with stock suspension, but it wont have a stuffed or slammed look most think its good.
Old Aug 10, 2002 | 04:14 PM
gunmax's Avatar
Go with the H&R springs and your 245/35/19's and you will have no rubbing.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
jaydot901
Sep 29, 2015 01:18 PM
