Throttle back cable tension
Old Aug 16, 2002 | 04:39 PM
Tanman's Avatar
My throttle deceleration cable (the one closest to the cabin) keeps getting loose. So the other day I tightened it to about the same tension as the acceleration cable (the one closer to the engine). Now when I accelerate past 3000 rpm, then let off the accelerator, the engine will stay at 3000 rpm, until I lift up on the accelerator with my foot, then it goes back down to 1000 rpm at idle.
This isn't a question, just information for anyone experiencing rough deceleration. It might be your throttle deceleration cable that's loose.
Old Aug 18, 2002 | 04:32 AM
wdave's Avatar
Re: Throttle back cable tension
I think that's the cruise control cable and it needs to have some slack in order not to interfere with the regular throttle which is closed by a spring, not another cable.
Old Aug 18, 2002 | 08:33 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
the one closest to the cabin is the accel cable. if you follow the other cable it leads through the fire wall and is the cruise control. i would not mess with that one but i did loosen up the nut around the accel cable and tighten it up a little bit.
Old Aug 18, 2002 | 09:32 AM
Tanman's Avatar
The problem I was having was with deceleration, and the accelerator cable was loose, so I tightened it up (maybe too tight?). The day after I tightened it, when I accelerated past 3000 rpm, the engine rpms would stay high until I forced the accelerator pedal up with my foot. But the day after, my car accelerated and decelerated normally, so I'm guessing the cable is at the correct tension (maybe it's loosened again).
Old Aug 18, 2002 | 09:52 AM
Green 2kSE's Avatar
This is basic question but did you remember to grease it first? Maybe the cable is binding a bit.
Old Aug 18, 2002 | 10:03 AM
sloppymax's Avatar
if you can look at it in terms of thirds, mine only has a third to the end of the cable. two thirds of the threads are above the position where mine is. i dont have a problem with idling, deceleration or any of the kind. it was an improvement from where nissan had it, much better response now.
JRod28
Dec 29, 2023 09:56 PM
vingodine
45
May 21, 2016 12:46 PM
Finkle
Sep 27, 2015 09:53 PM
schmellyfart
Sep 25, 2015 04:47 PM
Maximeltman
Aug 31, 2015 01:01 PM
