245 on 18x7.5? Trouble?
Old Aug 19, 2002 | 07:34 PM
DailleyDog's Avatar
I know the recommended size is 235 but how much trouble might it cause if I went 245? The rims I like right now are 18 x 7.5. If I could find them at 8 inches wide I would but they're not offered. Thoughts?
Thanks.
Mike
Old Aug 19, 2002 | 08:03 PM
TellschMax02's Avatar
Re: 245 on 18x7.5? Trouble?
Thanks.
Mike
As long as you get a 45 profile you are fine.
A messed up speedo (3.2% slow assuming 17" 225 50 Stock Tire) - but Tire and Rim Association says that will work.
I wouldn't do it.
Brian
Old Aug 19, 2002 | 08:10 PM
DailleyDog's Avatar
I was thinking 245/40, not 45 on the 18. That puts it under 2% variation from my 215/55/16 stock tire. Would you do it then?
Thanks.
Mike
Old Aug 19, 2002 | 08:12 PM
Newman's Avatar
the speedo isnt really what you should be worrying about. a 245 tire wont hug your 7.5 rim like a tire is supposed to. it is technically a little bit too big.
BUT i dont think you'll really have any major problems. it just isnt the best thing to do.
Old Aug 19, 2002 | 08:16 PM
According to Tire and Rim Assos - 245/45/18 will work on a 7.5" rim.
No less no more.
Brian
Old Aug 19, 2002 | 09:32 PM
Axel's Avatar
No less no more.
Brian
He was looking at 40 instead of 45. 45 will work, 40 won't.
245/40 18
Range: 8-9.5"
Recommended: 8.5"
245/45 18
Range: 7.5-9"
Recommended: 8"
Old Aug 20, 2002 | 02:34 AM
irvine78's Avatar
235 is the maximum width you can go on a 18x7.5 wide rim.
Old Aug 20, 2002 | 06:17 AM
245/40 18
Range: 8-9.5"
Recommended: 8.5"
245/45 18
Range: 7.5-9"
Recommended: 8"
Correct.
Old Aug 20, 2002 | 03:31 PM
y2kse's Avatar
Nope. 245 is the maximum width you can go on a 18x7.5 wide rim. Check it out in the Tire and Rim Association Tables on page 5 of the FAQs.
14GmMax
59
Aug 4, 2019 11:26 AM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
