RSM questions
Old Sep 1, 2002 | 04:33 PM
MyownNismo's Avatar
Future Camaro SS owner
RSM questions
Ok I have it installed and ready to go.But when I drive I will get up to 40mph and on the RSM it says I am going 240 kph already. Y2kevse or anybody else who has one tell me how you have it set up.
current set-up
1. cyl. 6
2. sp1. 2p
3. adj. 100%
4. tire 100% (stock 17's)
5. wght 2000 kg
Can you help me out.
Old Sep 1, 2002 | 04:36 PM
Sprint's Avatar
Happy Birthday
Old Sep 1, 2002 | 04:53 PM
MyownNismo's Avatar
Originally posted by SprintMax
Happy Birthday
I thought nobody would see that thanks.
Old Sep 1, 2002 | 05:26 PM
MyownNismo's Avatar
Re: RSM questions
current set-up
1. cyl. 6
2. sp1. 2p
3. adj. 100%
5. wght 2000 kg
Got the speed fixed now setup is like this
current set-up
1. cyl. 6
2. sp1. 8p
3. adj. 100%
5. wght 2000 kg
Old Sep 1, 2002 | 06:00 PM
ajahearn's Avatar
kilograms
I don't know about the 00 Max but the 02 weighs (according to nissandriven.com) 3320 with a MT. That would put it about 1505kg. The manual says to use 60kg for driver (132 lbs.) and 70kg for fuel. So unless you weigh a lot or the fuel weight is wrong, I think you need to lower that number.
Old Sep 1, 2002 | 06:39 PM
MyownNismo's Avatar
Re: kilograms
no mine on the side of the car says 4333lbs I weigh 135 and I added for extra cargo and fuel which brought it to 1999kg which I rounded up to 2000kg instead of 1990kg. I only went with what's on the side.
Old Sep 2, 2002 | 01:07 AM
MyownNismo's Avatar
Re: Re: kilograms
This is the best mod I bought so far.
Old Sep 2, 2002 | 07:24 AM
woosh's Avatar
Re: Re: Re: kilograms
Doesn't it just remove your speed limiter at this point?
Old Sep 2, 2002 | 07:27 AM
mingo's Avatar
happy bday man
Old Sep 2, 2002 | 10:18 AM
DrVolkl's Avatar
Re: Re: kilograms
Ok, here's an interesting point...the 4333lbs on the side is the GVWR. In the maxima brochure, they list the curb wieght at 3224lbs for the 6spd SE. What's the difference?????
(What is the GVWR??)
Old Sep 2, 2002 | 11:35 AM
MyownNismo's Avatar
Re: Re: Re: Re: kilograms
yes it removes your speed limiter but also does other stuff that I haven't done yet. like getting rid of some loss power if I read that right. As for the weight I know a auto weighs more than a 5 spd but I don't think by that much.
Old Sep 3, 2002 | 07:04 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
3250 is a good estimate on the weight of the car.
Old Sep 3, 2002 | 07:54 AM
ajahearn's Avatar
GVWR is Gross Vehicle Weight Rating and I believe is a maximum estimate of weight (probably assuming 4 passengers, luggage, etc.).
Old Sep 3, 2002 | 11:57 AM
Kojiro_FtT's Avatar
Re: Re: Re: Re: Re: kilograms
You don't gain any power from the RSM, it is only a gauge. What you read was about the G-sensor, which will detect wheel spin and give you a much more accurate power reading.
Old Sep 3, 2002 | 04:31 PM
MyownNismo's Avatar
Re: Re: Re: Re: Re: Re: kilograms
like I said (if I read right) it's new and I am just finding stuff out.
Old Sep 12, 2002 | 01:53 AM
MyownNismo's Avatar
Re: Re: RSM questions
current set-up
1. cyl. 6
2. sp1. 8p
3. adj. 100%
5. wght 1640 kg
just updating this for A33 for when he installs his.
Old Sep 15, 2002 | 04:59 PM
a33's Avatar
a33
i had the speed problem too at first but i fixed it...
now i have a problem with the horse power... i always get negative horsepower.... anyone know how to fix it????
and how do i adjust the setting for the tires if i am not using stock tires??? i have 235 40 18 tires...
Old Sep 15, 2002 | 05:23 PM
MyownNismo's Avatar
new tire diameter divided by stock tire multiplied by 100
EXP skyline R33 factory tire is
225/50-R16 dia. 632mm
new tire 245/45-R17 dia 652mm
652mm diveded by 632mm X 100 =103 103 is the corrections number that's what you would put. You need to measure your tires.
as for the did you get the g-sensor it only works with the g-sensor.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
