rear end hop
Old Sep 3, 2002 | 10:16 AM
turdleracer's Avatar
rear end hop
I have a 2002 maxima se (6 speed) and am having an awful time with the rear end hopping around whenever I go over a bump. It's bad enough that the car is very unstable when it happens. How can a manufacturer create a car with so much power and then give it such horrible handling!! It's unsafe!
Anyway, does anyone have a suggestion to resolve this problem?? I used to have a '92 maxima se...it had an independent rear. What a difference!I have a 2002 maxima se (6 speed) and am having an awful time with the rear end hopping around whenever I go over a bump. It's bad enough that the car is very unstable when it happens. How can a manufacturer create a car with so much power and then give it such horrible handling!! It's unsafe!
Old Sep 3, 2002 | 10:22 AM
mzmtg's Avatar
Minister of Silly Walks
...god bless the beam...
The hop is due to the fact that we dont have independent rear suspension.
There is a link in the 4th Gen FAQ thread about it.
Old Sep 3, 2002 | 10:33 AM
I already figured that part out! What I need to know is if there is anything that can be done to correct it!!
Old Sep 3, 2002 | 11:47 AM
Triple8Sol's Avatar
I miss the .org!
Buy an Altima. Or some shocks/RSB might help too...
Old Sep 3, 2002 | 11:50 AM
TimW's Avatar
The silent but deadly Moderator
you could try a RSB, and it would keep your bumps alittle more controlled. But then you'd need to consider than you may not be able to feel when the backend is getting loose and about to break free. Its a definate improvement, but you cant drive ***** out stupid with it or you'll smack a guard rail or curb.
Old Sep 3, 2002 | 12:14 PM
woosh's Avatar
This may sound weird
but I noticed the hop minimized a bit when I made the rear tire pressure 1/2 - 1 PSI more than the front.
Now that the weather is getting cooler the front PSI only seem to increase about 1/2 PSI so the rear pressure is only 1/2 PSI more.
33.5 front
34.0 rear
This is just my personal observation, hope it helps
woosh
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
BkGreen97
Apr 2, 2016 05:47 AM
AcuraLegend
Sep 22, 2015 04:22 PM
doctorpullit
Sep 10, 2015 06:33 PM
