4-speed automatic transmission w/OD
Old Dec 18, 2000 | 01:17 PM
F1 Rox's Avatar
How many times should it shift?
Do you get 4 gears + OD
or
3 gears + OD
I only hear 3 shift on my way to 70...
My RPM is 2000 around 60 m/h...
Old Dec 18, 2000 | 01:22 PM
punkdork's Avatar
Its a 4 speed transmission. The last gear is OD. Once you are cruising at 70 you should be in OD.
Old Dec 18, 2000 | 01:30 PM
nm's Avatar
nm
If you want more/detailed information on the AT take at look at the service manual, in there they have the gear ratios for the MT and the Auto and the Auto's shift points at different throttle positions.
p.s. interesting note about the gear ratios in the Auto: the 1st gear in the auto is approx. the average of the 1st and 2nd Manual gears and the 2nd gear in the auto is the approx. average of the 2nd and 3rd manual gears. The top 2 gears are virtually identical.
Old Dec 18, 2000 | 01:36 PM
MrBurner's Avatar
if overdrive is off, you only have 3 gears and if it is on, you have 4...if you like to downshift to slow down in an auto...when you are in 4th gear just hit the overdrive button...it is not as severe of a downshift as going from 3rd to 2nd but you can still feel the car start to slow down
here is what i have found my car does when flooring it
1st-43mph
2nd-75mph
3rd-110mph
4th-? haven't taken it over 120 so i don't know where 3rd gear maxes out
MrBurner's Avatar
1st-43mph
2nd-75mph
3rd-110mph
4th-? haven't taken it over 120 so i don't know where 4th gear maxes out
Old Dec 18, 2000 | 07:57 PM
1st-43mph
2nd-75mph
3rd-110mph
43mph in first gear, Really? What mods?
heres mine:
1st-39mph
2nd-74mph
3rd-112mph
4th-124mph...Thats maxed out too
This is in fully automatic mode shifting at 6,000rpm's.
user 11122324
42
Jul 18, 2022 03:35 PM
ef9
Oct 4, 2015 08:43 AM
Pied
Sep 26, 2015 03:29 PM
