Is there a write up on HU removal?
Old Oct 13, 2002 | 09:15 PM
Fezzik's Avatar
I tried to do a serach for this but did not find anything. i was wondering if anyone has done a write up on taking out the HU or installing extra wiring required for the 6 disc changer. Thanks!
Old Oct 13, 2002 | 10:24 PM
BigDogJonx's Avatar
Fairly simple, just remove the top AC vent and there are two screws there, remove them both.
Then remove the Ash tray like deal, remove the one screw in there, and lift up the shift console dash/cover, and you will see two lower screws that hold the bracket. Remove them both, then unplug and the whole bracket holding the radio and AC controls is in your hand.
Dixit
Old Oct 14, 2002 | 12:00 AM
PHATMAN5050's Avatar
It may be simple in that it does not require 50 steps, but there is NOTHING simple about removing the AC vents. But yes, BigDog is right about what you do. If you have any trouble just write back, I had to remove my HU like 10 times while I was installing my deck, so I'm a PRO
Old Oct 14, 2002 | 09:23 AM
WizzaMax's Avatar
Go to www.maximadriver.com and you find the HOW2 there...
also www.installdr.com document 647021 for non-Bose
Old Oct 14, 2002 | 09:49 AM
Fezzik's Avatar
Ok, I am running wire to the back trunk. Is it tough getting the wire run under the carpet back to the trunk?
Old Oct 14, 2002 | 11:30 AM
TimW's Avatar
The silent but deadly Moderator
no, its not
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
