Coolant hose... something isnt right
Old Oct 22, 2002 | 10:21 AM
ATt's Avatar
ATt
I was inspecting the coolant area, and noticed that I have a tear in the hose coming out of the coolant container. I'm going to get this fixed, needless to say. But does anyone know how bad this is for my engine? Is it not getting any coolant because of this?
Pic of engine with the hose highlighted for better perspective
Also, the fluid level is below Min. How should I go about this? Will adding fluid be pointless because of the tear? Should I top it off anyway? Or just drain/flush/refill normally.
Old Oct 22, 2002 | 10:28 AM
NYC2SD's Avatar
Are you sure you're not talking about the overflow hose. They have one to vent the reservior in case it gets too hot or overflows. (so it doesn't explode) Is there coolant all over the place??
Old Oct 22, 2002 | 10:33 AM
ATt's Avatar
ATt
I'm not sure what the purpose of the hose is. There isnt coolant all over the place, but the tear has white residue on it.
Old Oct 22, 2002 | 11:15 AM
mdeal's Avatar
That's the overflow hose. It can be easily replaced by first removing the overflow container from the body, holding it higher then the radiator, then changing the hose. You can swap out the hose as is but risk getting fluid water all over the place. It's a simple procedure if you want to do it yourself (I swapped mine when I installed my Hose Techniques hose).
After fixing the hose, you should be able to add a little water and be fine. If you had cooling problems you'd probably know by now. If the temp gauge stays in the middle under normal operating conditions then you are ok.
Old Oct 22, 2002 | 01:46 PM
ATt's Avatar
ATt
thanks guys
Miket2006
Mar 1, 2021 03:55 AM
captchaos
Mar 15, 2016 12:18 PM
foodmanry
Sep 24, 2015 12:02 PM
msellas
Sep 23, 2015 09:16 PM
junito1
Sep 23, 2015 12:14 PM
