torque wrench...
Old Oct 27, 2002 | 08:15 PM
SoloMaxima
torque wrench...
this might seem like a dumb question...
but does anyone know how to use a torque wrench..??..i got one from my friend but he lost the instructions and i got no idea how it works...i wanna install a fstb..i'm afraid of tightening it too tight or too loose...
thanx
Old Oct 27, 2002 | 08:29 PM
SkyDaver's Avatar
Depends on what kind.
If it's a beam type, you pull carefully until the indicator beam deflects to the desired torque.
If it's the 'click' type, you turn the knurled end of the wrench (NOT the nut on the very end) to the desired torque, then pull until you hear a 'click' and stop pulling.
Set it to 40lbs, and try it out on your lug nuts.
Old Oct 27, 2002 | 08:40 PM
Cutler's Avatar
80 ft lbs for your lugnuts
Old Oct 27, 2002 | 09:09 PM
SoloMaxima
thanx...
Old Oct 28, 2002 | 04:16 AM
Colonel's Avatar
Old Fuddy Duddy
I think he was referring to the fact it will give him the "click" and "feel" at 40 ft/lbs on lug nuts. A test if you will. And yes spec on lugs are 80 - 85 ft/lbs.
Old Oct 28, 2002 | 02:48 PM
SkyDaver's Avatar
Exactly. If you set the wrench to 40 lbs, and try it out on your lugnuts, you'll feel the click, and be VERY unlikely to put more than 80lbs of torque on the nuts.
If you set it at 80, and don't understand what you're trying to experience, you might put a lot of torque on the nuts.
As long as you loosen them and retighten properly, you'll probably be OK (unless you break the studs), but by using a low torque setting, you'll gain the experience of the feel, while greatly minimizing the risk of over tightening.
Mar 12, 2020 12:06 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
The Wizard
24
Oct 1, 2015 08:47 PM
dcam0326
Sep 18, 2015 04:52 PM
