Tire pressure minders
they cost $10.00 for a set of 4 @ Autozone.
i pressure my tires 33 all around & use a 36 psi tire minders.
reasoning: when presure drops 4 psi below the rated minder value the minder changes color to yellow, and red 10 psi below. this will alert me at 32 psi (and red @ 26 psi - not recommended to wait that long)
Re: Tire pressure minders
The tire minder thing is a good idea, but does it look okay hanging out that far off your tire?
Re: Re: Tire pressure minders
Re: Accurate????
Originally posted by ghostrider17
Have you tested these for accuracy???
Curious......
g.r.
Curious......
g.r.
i just have to trust the manufacturer on this - just like the pressure gauges you buy.
How to check the accuracy
I would think if you use a tire pressure gauge to check it at different colors illumination you could get a ball park accuracy.
If the pressure read from the tire gauge is the same as the trigger values (for the 36, trigger at <32 and <26) then you could say its accurate.
Originally posted by Raf2kMax
just for cosmetics purposes, id prolly leave em on my car when its parked overnite and then check em in the morning and replace em right after.
If you are going to do that you might as well check the pressure with a gauge.Any concern that the extra weight will cause pressure on the valve stem? How noticable are they, I was thinking about getting some because I am lazy.
Thanks!
But hey, they may be wrong. Keep us posted!
Arrggghhhhh!!!!!!
