Any interest in a GB on PocketDyno?
Originally posted by Y2KevSE
Bling bling!
My RSM can do all that for much less... AND I don't need a PDA to use it.
Bling bling!
You can get a lot of dyno pulls done for $350, and CarTest2000 ($40 dolla) can give you pretty accurate performance numbers based off of said dyno's.
Wrong...
Bling bling!
Bling bling!
2-The RSM look is RICE.
3-The RSM is a permanent fixture.
4-The RSM requires splicing into factory wires.(Some of us have a "warranty" to TRY and use)
5-Try storing multiple runs and overlaying them to see before/after differences.
6-Too many damn button pushing to switch modes, turn things on/off, reset, etc...
7-etc...etc...
The biggest difference is the ability to store data and transfer it to my PC, which allows a lot more data interpretation. Plus, I don't have to worry about pulling over and trying to read/analyze the data from the RSM, instead I can just save it and make more runs to view/analyze later. The RSM is a cool device, but it's lack of memory and downloading data is NOT worth it for what I would use it for.
Originally posted by SteVTEC
seriously! That thing works the same exact way as a G-Tech/Pro (accelerometers) only it interfaces to a PDA and gives you a little more data.
Dyno pulls are limited in their scope. Yes, a dyno analyzes engine output, but not in real world situations. Not to mention, how many trips it would take to the dyno shop just to tinker around on the weekend. I'd easily spend 10x that much on dyno time here. A dyno is not very applicable for the type of stuff I or most people do, while tinkering. A dyno is more of a benchmark of total gains at a particular time NOT something you can make changes and see if it helps/hurts performance. Dynos are a waste of time unless your trying to "tune" A/F.
CarTest is not going to allow you to tweak/try different things in the real world. It's a VERY good simulation for known parameters, but doesn't count on the unknowns which is MOST OF WHAT I CARE TO TEST.
Re: Wrong...
1-I already got a pda that I don't use laying around.
=== I can get my hands on one too.
2-The RSM look is RICE.:-p
=== That's why it's cool.
=== Nope, you can always take it off if you plan the wiring procedure correctly.
=== Can be hidden without a problem.
=== RSM can store multiple runs also.
=== Same for PDA.
7-etc...etc...
What's there to analyze?
0-30 MPH time
30-50 MPH time
0-60 MPH time
¼ Mile ET
¼ Mile MPH
60 feet time
Maximum g's for acceleration and braking
Maximum g's for left and right turns
Estimated ¼ Mile time and speed
Estimated Engine Horsepower
If it can pull other stuff then that would be cool (i.e. Pepper's ODB-II thingy). You can buy an RSM AND ODB-II scanner for a little bit more (~$20).
=== Same for PDA.
7-etc...etc...
0-30 MPH time
30-50 MPH time
0-60 MPH time
¼ Mile ET
¼ Mile MPH
60 feet time
Re: Re: Wrong...
=== That's why it's cool. :cool
Too much crap for my taste, but that's fine for your flava and EXTREME Maxima. I would just rather have something that's EASY to install and uninstall to be used ONLY when being used.
Yeah right! Most of US can't even splice two wires correctly and you think that's not a problem to conceal. Especially, if there is a "mysterious" electrical problem and Nissan is on a witch hunt. It's permanent, the wires are pierced/cut and will always show tampering.
=== Same for PDA.
=== Same for PDA.
0-30 MPH time
30-50 MPH time
0-60 MPH time
¼ Mile ET
¼ Mile MPH
60 feet time
If it can pull other stuff then that would be cool (i.e. Pepper's ODB-II thingy). You can buy an RSM AND ODB-II scanner for a little bit more (~$20). :kiss
I'm not trying or going to sell everyone(maybe ANYONE!
) on this, I just think for a LOT of weekend tuners and tweakers this is a GREAT tool to have instead of a G-Tech Pro and ESPECIALLY the butt dyno.
How is a dyno not representative of real world situations?
If your tinkering involves making very small changes to your car, I can pretty much guarantee that a G-tech just isn't going to have the accuracy/resolution to tell you anything meaningful. Dynos can see very small differences, but G-Tech's cannot.
err..I don't think so. Granted, this PocketDyno thing is cool, but I just don't see how it's really all that much better than a regular G-Tech for over twice the price. I suppose the 60' time measurement would be nice, if it's actually consistent enough to be useful.
So what unknowns are you trying to test?
Wussy....
I'll reply when I get home.
Don't bother Kev. Just reply to my BIG email sooner rather than later.
Have you ever uses a G-Tech Pro? If so, you'd know it's a bish sometimes to get anything consistant and then you have to depend on your note taking skills to record/catch info. Sometimes, if your not quick enough the data is lost. The Data logging is the biggest difference IMO.
The data logging and interface to PDA is neat yeah, but is it worth an additional $200 over a regular G-Tech/Pro? You decide. If you have money burning a hole in your pocket that you're itching to spend then have at it and don't let me stop you. hehe ;-)
You don't want to know Steve! Hehe. Let's see. TB opening angle, airfilter vs. no airfilter
OSACI vs. POP, Stillen POP with/withOUT Franken midpipe
The smaller the changes you're trying to test, the greater the error percentages will be. You can still get reasonable data, but you just have to run the same tests over and over and over and over again to statistically calculate out the error and get standard deviations, etc.
Like I said, $350 buys a lot of dyno time
If you want to see the difference with the Frankencar Mid-pipe, tell Steve (dmbmaxima) to dyno it so that we can all justify spending another $50.
I'm pretty sure Paul2kGXE did a dyno of the OSCAI and posted the results at his page @ www.paulwendy.com I checked, but it looks like he took his Maxima stuff down. But he's still around. If you can't find stuff here just email him.
And MaxSE2k just did a dyno comparing a CAI to a WAI
unbolted cat
unbolted cat
Someone here with a 4th Gen auto did a dyno with stock cat and 3" RT cat. I don't know how much more a test pipe would give you, but I'm sure there's a dyno floating around somewhere for that too.
double clutching vs. regular, side stepping the clutch vs. granny shifting
Granny shifting (0.5s shift, 0.2 engage) 00 5spd: 15.2 @ 93
Speed shifting (0.2s shift, 0.1 engage) 00 5spd: 14.9 @ 94
So about an 0.3s and 1 mph trap between granny shifting and speed shifting. There was just a thread here a little while ago where somebody had a good trap but their ET was just slow and they mentinoed that they really weren't shifting that fast. ding ding! =)
RPM shift point
RPM shift point
Adjusting the redline to 8000rpm in CarTest on a VQ30DE-K, the optimal shift points are calculated to be:
1-2: 7630rpm
2-3: 7080rpm
3-4: 6880rpm
4-5: 6590rpm
CarTest:
1/4 mile w/redline shifts: 14.9 @ 94
1/4 mile w/above shifts: 14.8 @ 94
But since the rev-limiter is well before all of those optimal shift points, you're stuck with wherever the rev-limiter is set at.
tire pressure
tire pressure
Redline engine and tranny oil
you know anything that's a bored mind can get into on a Saturday afternoon.:naughty :
And don't limit yourself to just Maxima.org searches. Internal combustion engines, transmissions, and cars in general all work the same way. If you find a technical article for a Miata, it will apply in some way to a Maxima also. Just remember to keep engine sizes in mind. If you see a Miata intake dyno good for 4HP, then multiply by two to get the approximate gains from the same mod on a Maxima since the engine is twice as big.
The Miata pages/forums are AWESOME places to get tech info. It's an awesome car that's just never had much power. There isn't much that those guys have *not* explored/tested/dynoed in the quest to get more speed out of their cars.
Another great place to look for N/A tuning options are muscle car pages. Lots of these guys have been hot rodding their domestics and running down 1/4 mile strips for longer than most people here have been alive. And any N/A tuning trick is also applicable to a VQ. They are afterall, internal combustion engines too.
Want to learn about turbo's? Checkout www.i-club.com the WRX forum. I didn't know this, but the WRX has actually been around for close to 10 years. It's only in 02 that it finally came to the US. There are lots of very mature tuning options for those cars, and it's a highly technical forum. The best part is, a lot of the big name WRX tuners are REGULARS on the forums, always posting up their latest tests and product info with actual dyno's, along with helping people out with their cars. I once spent an ENTIRE WEEKEND reading and learning about turbo setups and tuning obstacles. You could probably do the same thing at SupraForums.
Want to learn about S/C's? Search here =)
You brought up a KILLER point about the redline shift. I'm going to use it as my shift indicator(light) next time I go to the track. I've always figured the best possible times from a VQ30DE-K are by bouncing the REV limiter in 1-2 and 2-3. The question is whether or not to lift on the gas pedal, but since I naturally don't, I'll find out soon enough.
Thanks for the advice about the other forums, I'll check them out.
Already tried...
Originally posted by VQ30GTR
How about pocketlogger.com ? They have one for $175, one of motor trend magazines I think it was, said it was a nice aftermarket addition to their subaru impreza wrx.
Anyways, I'm still looking for something with G-Tech or RSM abilities AND OBD-II INTEGRATED. One of these days, maybe I'll get frustrated enough and just write my own. LOL!
Turbonut
46
Oct 21, 2015 08:28 PM
ToTheMax305
Sep 23, 2015 09:11 PM
