Tein S. Tech Spring kit?
Old Nov 8, 2002 | 12:58 PM
Titleistprov21's Avatar
Has anyone ever heard of these springs (Tein S. Tech Spring kit)? They are a lot cheaper than the eibachs and give you more or a drop (2.2in FR, 1.6 RR). That sounds good to me, because the wheel gap in the front of my car is TWICE as big in the back of my car (Four finger wheel gap in the front, and 2 finger in the back). Any one have any advice how these springs are compared to eibachs? Here is the link www.optauto.com Click on suspension on the right, then nissan, then you know the drill. Anyone have any feedback or comments?
-Pat
Old Nov 8, 2002 | 02:00 PM
jykishan's Avatar
wow, i didnt know we had springs that dropped that low, I would buy them if i had money
Old Nov 8, 2002 | 02:59 PM
Tai Mai Shu's Avatar
Tein is a premier performance suspension manufacturer in Japan. Going to get a set of coilovers from them for my S13 soon.
Old Nov 8, 2002 | 04:05 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Re: Tein S. Tech Spring kit?
-Pat
Buy them!
So we can see how EVEN the drop is.
Old Nov 8, 2002 | 04:18 PM
IceY2K1's Avatar
More info....
http://www.tein.com/stech.html
Spring Rates
Front(kgf/mm,lbs/in)
3.6/201
Rear(kgf/mm,lbs/in)
4.8/269
Ride Height
Front(mm/inch)
-55/-2.2
Rear(mm/inch)
-41/-1.6
Old Nov 8, 2002 | 08:41 PM
IceY2K1's Avatar
Can ANYONE tell me how these spring rates relate to others such as H&R and Eibach?
I'm sooooo tempted and ready to buy something.
Old Nov 8, 2002 | 11:15 PM
SG01MaxSE's Avatar
WOW!
Looks like a GREAT deal! Tein makes quality stuff. I'd consider them if I hadn't just ordered the Maxspeeds !!! Then again, I'm still on stock struts, so I'm not sure if I'd want that much drop.
Old Nov 9, 2002 | 12:29 AM
AzNx2k2xSEXima's Avatar
i can't see ....the optauto is messed up.....or its me....cuz whenever i go to a nissan suspention thing....it reads...some something part not available for bla bla...... $220??? hmm....who can be trust more...eibachs have the lifetime warantee right? so....lifetime vs. 1 yr??? i think the tein's would look pretty sweet though...
Old Nov 9, 2002 | 12:58 AM
d_warner's Avatar
Old Timer
-Pat
Dang. 2.2" drop in the front. I could never make it where I live. I'd have to mount a winch on the front of the max for ever time I high centered or bottomed out. But hey. Go for it man. Let us know.
Old Nov 9, 2002 | 09:50 AM
Blu's Avatar
Blu
the tits
wonder how long the stock struts would last on these. So far my H&r's are doin good on the stockers
Old Nov 9, 2002 | 12:26 PM
IceY2K1's Avatar
I think your going to find out soon enough!
Old Nov 9, 2002 | 04:55 PM
2kSeattleMax's Avatar
Think a drop that significant would require a camber plate kit for the front too.....
Anyone else concur? I do know that Tien makes good stuff.
Old Nov 9, 2002 | 05:12 PM
IceY2K1's Avatar
Not sure.
Would the Eibach camber bolts be enough or do I need the $$$$ on the plates?
Old Nov 9, 2002 | 08:23 PM
What is a camber plate kit? How much does it cost?
Old Nov 10, 2002 | 01:21 AM
Camber is the tilt adjustment on your front wheels. Any changes in excess of 2" place the car so low, there isn't enough adjustment left in the factory camber to make your tires sit level on the road. / \ unstead of | | if that makes sense. Anyhow, the camber plates fix that....
I'm sure there is someone here who has experience in doing a 2" plus drop with camber plate adjustments.
Found EIBACH part number for their "Alignment Kit"
NISSAN, Maxima - 2000
(Incl. GLE, GXE, SE & XE)
Product Front Rear Comments Part Number
PRO-KIT 1.3 in 1.0 in Varies by engine size and or model. 6350.140
ALIGNMENT KIT Front +/- 1.75 degrees of adjustment. 5.81250K
Old Nov 10, 2002 | 12:11 PM
IceY2K1's Avatar
Pics!!!! CRAPPY though, photochopped?
Side shot is too large:
http://www.tein.com/ti/img/kp202.jpg
Old Nov 10, 2002 | 12:14 PM
IceY2K1's Avatar
I don't think my Stillen AERO lip is going to last long.
Maybe the AE front 3-piece lip would give more clearance with the Stillen sides and rear?
Old Nov 10, 2002 | 05:55 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
I lowered my 01 GXE 3.0 in the front and 2.0" in the rear I run modified Koni Yellows in custom strut sleeves. Actually going to run 600-500 spring rates on my GCs now cause I find em little too soft with 400-300 rate, anyone want to buy just the coils ? I find that the extra degree of negative camber doesn't eat up the tires much at all- I usually get 7-10K miles out of front tires anyways. Plus it gives the car less understeer durring high speed cornering around Road America :P
Mike
01 Max GXE 5spd, every bolt on, 14.1@97MPH going to dyno this month to tune the S-AFC more and my custom ECM.
93 SE-R forged bottom end, Fmax, Garrett, Forge, lots of $$$, needs some more tuning, its turbo :P
Old Nov 10, 2002 | 09:21 PM
IceY2K1's Avatar
BlackBIRDVQ...
Mike
Do you have any pics?
Also, what "custom ECM" are you running?
Old Nov 11, 2002 | 06:06 AM
Well, i think i am going to go with the eibachs. Only because they are garunteed for life, and the Teins are only garunteed for a year. I have another question, Does anyone know why my car is so off balance? with a 4 finger wheel gap in the front, and only a 2 finger gap in the rear? When i put on the eibachs, it will still be a little off balance but not as bad. Does anyone else have this problem?
Old Nov 11, 2002 | 08:14 AM
the car is balance...
the reason why the front fender gap is so big is b/c the front 2 tires turn, and the rear duzn't...
like...they dont want to tires hitting the fender on turns...
well thats what i assume
Old Nov 11, 2002 | 09:05 AM
PearlRalizinG2k's Avatar
this is a god deal!
i think i am going to order a set soon and replace the eibach that i cut!!
i cut 2(two) coils of of my front eibach and i love the way it looks and ride quality is gone off course!hehehehheh well i'd say it's still better than some Honduhs!!!!
Old Nov 11, 2002 | 09:08 AM
IceY2K1's Avatar
Re: this is a god deal!
I already ordered mine!
However, it says "out-of-stock", but at least I'll still get the same price when they do get in stock.
I'm just worried about hitting the bump stops and driving with a 2.2inch drop w/Stillen lip.
Old Nov 11, 2002 | 09:18 AM
Blu's Avatar
Blu
the tits
Re: Re: this is a god deal!
watch those speed bumps and parking lot entrances scruuuuuuuuuuuubbbbbbb.
Old Nov 11, 2002 | 09:21 AM
IceY2K1's Avatar
Re: Re: Re: this is a god deal!
Old Nov 11, 2002 | 09:25 AM
lcf's Avatar
lcf
I like the drop in the front... but I really hate how a car looks when the drop is uneven.
I'm sticking with saving for coilovers.
Old Nov 11, 2002 | 02:30 PM
rob van dam's Avatar
ummmmm
to get these springs or coilovers...HUMMMM..do they actually drop that low...ummmmm....my eibachs dont drop even!.....what to do what to do?...
albert
Old Nov 11, 2002 | 02:32 PM
IceY2K1's Avatar
Re: ummmmm
albert
Looks like you got a little time, since optauto is out-of-stock.
However, once they get in stock they will probably be at retail which will be $220-250.
Old Nov 11, 2002 | 07:08 PM
Triple8Sol's Avatar
I miss the .org!
I didn't realize Tein had come out with springs for 5th gens! That is a decent price, as we all know their quality is top-notch. If I were going with springs, I would definitely have to decide between the Tein S Tech or the Maxspeeds.
Old Nov 11, 2002 | 08:04 PM
well
maxspeeds...
Old Nov 11, 2002 | 08:05 PM
MaxedOut2g's Avatar
damn cant wait to see pics...im not liking my progress all that much now, being in norcal roads are sooooooooooo much worsethan socal, i miss socal roads...i might haveto hook up TEIN if it looks tight
Old Nov 12, 2002 | 03:57 AM
Intrax Sport Springs?
I decided not to go with tein, because i have a limited budget and i don't want to deal with camber plate system. However, i found that the Intrax SPort Spring drops a few tenths more inches than eibach and they say that they have a more comfortable ride. Anyone ever heard of them? or have them on their ride? Pics? Thanks
-Pat
Old Nov 12, 2002 | 08:52 AM
IceY2K1's Avatar
Re: Intrax Sport Springs?
-Pat
Camber bolts are $25.
Old Nov 12, 2002 | 11:51 AM
Re: Re: Intrax Sport Springs?
Yeah, camber bolts are $25, but camber plates are $300. I though camber bolts wouldn't do enough for a 2.2 in. drop
Old Nov 12, 2002 | 12:09 PM
IceY2K1's Avatar
Re: Re: Re: Intrax Sport Springs?
You only need camber bolts according to KevinG.
Old Nov 12, 2002 | 03:19 PM
Triple8Sol's Avatar
I miss the .org!
Re: well
maxspeeds...
What's so funny about that? Normally I wouldn't consider them, but people seem to have had good results with those on here. H&R ride/quality for 1/2 the price sounds pretty good to me.
Old Dec 1, 2002 | 11:59 AM
MaxxTuningUSA's Avatar
The guys at TEIN said you don't need any camber correction kit for their S. Tech Springs.
Old Dec 1, 2002 | 12:37 PM
Blu's Avatar
Blu
the tits
Re: well
maxspeeds...
what am I missing here
Old Dec 1, 2002 | 12:46 PM
Re: Re: well
i mean...i can't say anything about the tein springs...BUT...i have seen maxspeeds on a 2000 SE and a 2k2 6 speed maxima....and they don't drop LOW at all...i mean my eibachs drop lower,......in all HONESTY......if you do not believe me...go ahead and get them.....
Old Dec 1, 2002 | 12:48 PM
irvine78's Avatar
bah..warranties on spring...u don't really worry about warranties with springs...there's not much(if any) that can go wrong with coils!!! besides, TEIN makes pretty good stuff...i think that's good enough.
