automatic..and i am shifting!!!
some people have reported better times at the track by leaving it in drive. on the street, i shift occasionally. i put a trans cooler to deal with the extra heat by me cruising around 30-40 and dropping it in 2. if i know i can take the guy, i leave it in drive but if its going to be close i shift so i can take it as close to redline as possible.
see.....when i drive i try not to drive to crazy...just when people **** me off....so if i am at a light and some other car that can keep up with mine trys somthin with me...then i throw it in 1st w/ overdrive button pressed and the switch like its a manual...this is not good for the engine...right??? or is it ok once-in-a-while!!????
thanks for the info...i will take that into consideration!!!
Originally posted by Dario
i think id be more worried about the tranny messing up, the engine should be fine as long as you dont go past redline
When shifting, you have to shift around 500 rpms before redline if you want it to shift at redline, there is a little delay when shifting the stalk and shifitng gears. You have to play around with it to see what the best point is in each gear to get it to shift at redline. BTW, I got better times when manually shifting at the track.
yea, turning overdrive off won't affect anything until you either (a) let off the gas and the car shifts up for economy, or (b) accelerate past the range of 4th gear. i turn it off when i want to gun it, just so the car isn't dropping into higher gears at highway speeds (cause then i have to wait for it to downshift when i floor it), but off the line you'll never hit overdrive till you're coasting to a stop. think of overdrive as the "economy" button.
there is definitely a trick to manually shifting your auto, a little practice will give you a feel for it. even letting D do it will heat up the tranny without a cooler if you're flooring it.
get a feel for the range of each gear before you try it too much. stick drivers have a better feel for where their gears lie, us auto folks usually don't pay attention since we don't have to. you want to make sure you're at the right speed and rpm before you dump it into 2...
and mind the shift delay, like Greg's2kGLE said. shift a bit before redline, and downshift a bit above your target rpm when decelerating, since the tranny will be a few seconds behind you.
my butt-dyno measurements definitely show better acceleration when shifting myself. plus it's more fun.
if you're gonna do this alot, a tranny cooler's only 50 bucks! worth it!
and mind the shift delay, like Greg's2kGLE said. shift a bit before redline, and downshift a bit above your target rpm when decelerating, since the tranny will be a few seconds behind you.my butt-dyno measurements definitely show better acceleration when shifting myself. plus it's more fun.
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
