Static shock every time i get out of the car
Every time i get out of my 2k2 and close the door behind me i get a shock when i touch the outside of the door. Sometime the shocks are small, but a lot of the time they are pretty damn strong. It does it almost every time that it isn't raining. anyone else have this problem?
Re: Static shock every time i get out of the car
Every Time..without fail
Same for me...every fuking time. Sometimes I get zapped really good. It's happened for as long as I can remember, no matter what car I drive. I usually 'discharge' the static with my covered elbow on the door frame and then close the door with my hand.
Two solutions:
1. When you place your left foot on the ground to get out, hold a metal part of the car with your hand as you get up and out. (I touch the area next to the AE sills).
2. Get a anti-static strap (nylon or rubber strap usually seen hanging on mid to bigger sized trucks off the rear axle scraping the ground)
twin turbo power plant dreams
SHIFT_woosh
SHIFT_woosh
At night, look at the arc between your finger tips and the door. It looks pretty cool and its actually bright. The most sensitive part of your body is the fingertips (most amount of nerve endings) that's why it hurts the worst.
Funny that so many people are miffed on this topic...
As any vehicle moves, it collects static energy, just as people do. Most limo's and taxi's have grounding straps to avoid shocking their patrons. It is worst in different climates. The only sure way to rid it, is to install a grounding strap from your frame to the pavement.
Originally posted by woosh
Two solutions:
1. When you place your left on the ground to get out, touch a metal part of the car with your hand as you get up and out. (I touch the area next to the AE sills).
SHIFT_woosh
Two solutions:
SHIFT_woosh
Just tap your key on a metal portion of the door. The key will get the ZAp, plus you'll see a nice spark
Yarrrr!
Once I got shocked twice in a row. I put my hand down on the door from inside where my windows are rolled down, got shocked once, pulled my hand away, put it in the same spot and got shocked again. Whats worse, I work in a computer company and I swear the whole place is statically charged. I'll walk around get shocked by doors, I leave to go to my car and then get shocked... I feel like a freakin' battery over here!
Originally posted by Titleistprov21
Damn this is funny! All these tips just to get out of your car!
I have a 2K GXE and have no such problems! Is it only on a 2k2?
Originally posted by Bluesbrekr
I don't think it's a grounding issue. It happens to me in all 3 of my cars...but all 3 have cloth interiors. Do you other guys have cloth? Do people with leather get zapped, too??
My 03 Max has leather heated seats, and lately, from the days that have been getting colder, I haven't as yet had any static shocks. I think it also depends on what coat or jacket you wear. If you wear a wool coat and sat on a cloth seat during a cold dry day, LOOK OUT!
My way around it was I use to close the door with my foot, and take the shock through that. You would see a sparking jump from the rubber sole on the bottom of my sneakers or shoes to the door, actually looked kinda cool, but the rubber would insulate the pain.
Originally posted by VQPowerSE
I use to have this problem when I owned my 93 T-bird and 01 Altima, both with cloth seats. No matter what I did, Especially if it was cold and dry outside, I would be guaranteed an instant shock!
Originally posted by Viciousss1
The best thing to do so you won't get shocked is to suck your thumb will your driving.
Now I have to find another g/f to do that for me
Whenever there is high amounts of humidity in the air (rain) you will NOT have static discharge. The reason why people notice static when it gets cold is because the air is dry, i.e. no humidity.
There is no such thing as plastic or rubber grounding strips. This two materials are INSULATORS!!! Electricity cannot flow through them. The straps that you see are actually carbon impregnated polymers, that have enough carbon in them to make the straps conductive. For passenger cars grounding strips don't work. The vehicle is not shocking you. You are zapping yourself.
The reason why women get shocked more is because they typically are wearing more synthetic fibers, undergarments, pantyhose, dresses, skirts, blah, blah, blah.
Just make absolutely sure you zap yourself before pumping gas. I saw an article in the Washington Post a while back that said that several people have caught on fire at the pumps because of static. Statistics showed women had higher incidence of this happening. It was thought that this is do to the fact that men generally stay at the pump while women get back in their car while the gas is pumping.
Originally posted by njmaxseltd
Next time spring for Leather interrior and you guys wount get shocked.
Wrong! I have leather interior and I often get static out of my 2k2 SE. I would like to hear more from static experts on how to PREVENT statics when closing my door.
Just curious, what kind of tires do you guys have?
FWIW: My pop worked in the tire industry for over 20 years and said that there is a direct relation between the tires you have and other environmental conditions. We experienced it very infrequently with the Potenza's on the Max but not since the SLE's. When I worked at his shop in the late 80's and early 90's we noticed that there were lots of complaints about static shock on the cars with Michelin MXV4 Energy tires on them. Dad said that a reduction in Carbon Black (the compound that makes rubber black and helps it resist the elements)to reduce expenses $ in production cost increases the car's ability to hold a charge since the rubber isolates it from the earth and prevents grounding.
All my cars in the past (5) had cloth interior and this problem affected me greatly when I use to live in Wisconsin. I don't see it happening as much now that I live in Texas, but on the other hand I now own a 2k2 Max with leather seats and the weather is not quite as dry.
As for a remedy this is what I use to do. One part fabric softener, scent as desired, two parts H2O. Mix solution put in spray bottle and spray away. It seemed to work for me. It did not stain my seats and made my car smell laundry fresh.
If this remedy doesn't suit your fancy the next time you slide out of your car try this. When your completly out of your car and your about to shut your door make sure your finger is in contact with the metal of the key not the plastic. Then reach and touch the door with your key instead of your finger to your inside door jam to discharge yourself.
Good Luck!
Good Luck!
On my 2k3 w/ leather
..I've yet to get shocked. I've had this on car's before and I just dealt with it. The gas pump thing is bad, but how much does this really hurt? When I was a kid I used to drag my feet around the rugs and touch the light switches! I couldn't wait until winter.
I think the problem isn't static, it sounds like people need to move to NY and toughen up!
Oh, the nice thing about static is that when your g/f p^isses you off, you can zap her!
Usually when the heat is on and you rub your feet on the carpet (and your back on cloth seats), it will cause static electricity...
Here's a link I found.. *shrug*
http://www.sciencemadesimple.com/static.html
Re: Re: Static shock every time i get out of the car
Originally posted by realtor
Just get out of the car without touching anything at all. Then tell your g/f to get closer to you and suddenly without warning, go ahead and discharge your static electricity by using your index finger on her ear lobe.
Originally posted by maximaman777
A week or 2 ago it happened to a guy in San Antonio filling gas cans in the back of his pick up. Not a pretty sight...
Originally posted by CCS2k1Max
That is what Darwin termed natural selection. If that guy had read the instructions on filling gas cans, aside from using "approved containers", it says to do it on the ground, not out of the back of a truck or trunk.
I just read something shocking regarding static shock in the papers a couple weeks ago...
Minnesota woman filling up gas, dies of static shock when she is putting on gas. Apparently, all the static electricity built up from her jacket, hat, seats and when she went to touch the gas dispenser, she touched the metal part first and there was an explosion
