Outside temp gauge...AMB
Old Dec 30, 2000 | 12:16 PM
Maximam's Avatar
Has anyone had any problems with the outside temp gauge being accurate? Mine seems to be always 5-8 degrees off.
Old Dec 30, 2000 | 01:20 PM
madmax2k's Avatar
Mine seems to be right on as long as the car is moving at a decent pace. Stuck in traffic, its way off as its sensing the engine and road heat.
Old Dec 30, 2000 | 01:35 PM
xydavid's Avatar
mine seems pretty dead on compared to weather.com. Keep in mind, it's measuring the temperature close to the road.
Old Dec 30, 2000 | 03:57 PM
TimW's Avatar
The silent but deadly Moderator
hmmm
mine is accurate when moving. Traffic or hot asphalt can skew it a bit...
Old Dec 30, 2000 | 05:05 PM
2000MaxSE's Avatar
Temp Guage
Mine is right on except if you pull your car out of a cool garage and start driving when you know that the outside temp is about 10 degrees warmer then the temp in your garage. It takes the temp guage about 20 - 30 minutes to adjust to the correct temp. I believe that Nissan made it that way to avoid the temp guage coming up in temp when you are sitting in traffic. It will adjust from a hot temp to a cooler temp much faster.
BTW: What does "AMB" stand for anyway?????
Old Dec 30, 2000 | 07:23 PM
mdeal's Avatar
AMB = abbreviation for "ambient"?
Old Dec 31, 2000 | 02:37 PM
Versace's Avatar
Does the temp guage only come with the automatic climate control system?
Old Jan 3, 2001 | 10:17 AM
mphilips's Avatar
I noticed the amb temp switch to farily accurate (+/-2 deg) kyw1060 says its 27 , i look at mine it says 25. Then if they measure the temp in center city, and your in the suburbs, its gonna differ. The amb is accurate to where you are at.
Old Jan 3, 2001 | 10:47 AM
NYC2SD's Avatar
Anyone know where exactly the sensor is located??
Old Jan 3, 2001 | 08:06 PM
2000MaxSE's Avatar
Sensor Location
The temperature sensor is located in front of the condenser in a metal enclosure with a small opening in it. This is to prevent a rapid exchange of air temperature.
Old Jan 3, 2001 | 09:05 PM
Maximam's Avatar
Maybe it is just me. I am glad to hear everyone elses AMB works fine. Mine just sems to be right on sometimes and way off others.
Mark
Old Jan 4, 2001 | 04:31 AM
Maximum Velocity's Avatar
Yes, it does mean ambient.
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
fastcarny
Oct 6, 2015 10:42 AM
msellas
Sep 23, 2015 09:16 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
