Lowering springs and camber kit
Old Dec 4, 2002 | 11:29 AM
Burton069's Avatar
I just put Maxspeeds on, and my friend told me that I should get a camber kit so the tires won't wear out unevenly. Anyone else have this kit?
Old Dec 4, 2002 | 11:36 AM
njmaxseltd's Avatar
Camber kit isn't needed on mild drops. Just get the car aligned.
Old Dec 4, 2002 | 11:45 AM
johnny2kgle's Avatar
It would not hurt to get camber bolts (Eibach) for an adjustment +/- 1 degree, cost $50.00 from tirerack or sw autoworks. You do not need camber plates (Stillen $300.00) if the drop is 2" or less.
Old Dec 4, 2002 | 01:38 PM
njmaxseltd's Avatar
Why buy the bolts if you don't need them? His camber will be fine with Maxspeed springs. $50 bucks is way to much for 2 bolts too.
You can get camber bolts from your local speed shop for about 20 bucks.
You can even use a high strength bolt from you local hardware store, smaller in diameter then your OEM bolt to give you more adjustment in the lower mount.
Total cost.... about 2 bucks.
Old Dec 4, 2002 | 01:47 PM
asu174's Avatar
Clay Aiken has fancy genitals
Agreed. With Maxspeeds you won't need anything. I never needed my plates adjusted with a 2"+ drop on Ground Controls. Waste of $$.
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
imported_Nismo_max
Feb 17, 2016 03:39 AM
BiggRoosta
Sep 23, 2015 08:53 AM
