I think mine Transmission is going
Yesterday while coming home from brooklyn. I started the car a drove put it into drive everything seen fine until i got around the corner and started to speed up. The car wont rev over 2000 rpm. Its stays at 2 rpm until i hit second gear then its gradually raises from then... there is absolutely no low end power coming from the car. and when i put it in reverse its just revs like in Neutral and there was a load bang and it car jerked then it finally got into gear...
I'm taking it to service early tommorrow morning...
By the way its a (2k automagic)...
I'm taking it to service early tommorrow morning...By the way its a (2k automagic)...
Originally posted by Nyc2kMax
by the way i'm at 54000k and i just had a month ago the oil, transmission fluid, coolant, drive belt, and the AC belt changed...
Let us know the outcome.
Re: I think mine Transmission is going
yup definately tranmission man...i had the EXACT same problems as you.
no reverse and no tourque and no rpms!
i took it in and they had for about 5 days.
after the new trans...man it felt good...at least you still have your warranty left or esle that would be killer...by the way, i did everything you did to fix it up, oil change, and tran fluid change tune up but nothing helped...its gotta be the transmission...i feel your pain..
good luck
the verdict from nissan isssssssssssss "THE TRANNY IS GONE"
WHY???????
they said they found metal filing in the transmission... But i dont understand I service the car regularly and I take good care of it, Could it be that nissan need to recall the 00 models for tranny problems... Its under warrenty so i will get back the car on friday...
WHY???????
Well, well ...well .. I am on tranny #2 at 53K. I had exact same problem for completely unexplained reasons. Tranny just went .. just like that. left home/backed out of parking garage.. got to my destination.. reverse was just gone. Good luck and enjoy the new tranny.
fast
WHY???????
WHY???????
don't worry, you'll love your new transmission...
it was just bad luck that it happened to us. thats all..
take care
Pied
Sep 26, 2015 03:29 PM
