Ebay FSTB does not fit 2002
Old Dec 17, 2002 | 05:23 PM
mrmark's Avatar
I purchased a FSTB on ebay (see link) http://cgi.ebay.com/ebaymotors/ws/eB...tem=1873331612
I installed it on Friday AM and then took the car to the dealer to have the tranverse link recall completed. On Saturday I noticed that when I put the car in reverse and had my foot on the brake, the car made this grinding sound. I though this was related to the service work...but today, after they researched the problem, its the engine hitting the FSTB when I put it in reverse. When the car is off there is clearance, but not enough when the car is put in reverse.
Anyone having this problem with their Ebay bar?
Im ****ed because I paid $80 to find out that my $25 bar was crap.
Mark
Old Dec 17, 2002 | 05:29 PM
Maximam's Avatar
Did you install the washers?
That looks exactly like Southwest bar and Bomz
Old Dec 17, 2002 | 05:31 PM
mrmark's Avatar
It didn't come with washers. If I add some, will that move it up enough to not have a problem? If, so how many washers on each bolt?
Old Dec 17, 2002 | 07:03 PM
Virus's Avatar
Stillen's does the same thing. I just live with it. It won't cause any damage and you don't here it if you take it slow like reverse was meant to be driven. There is a writup somewhere on how to shave your engine or your bar down just a tad to prevent the noise, but it's not worth the effort.
Old Dec 17, 2002 | 07:37 PM
Agent Chu's Avatar
Re: Ebay FSTB does not fit 2002
Mark [/B]
Why did you have to pay $80?
Old Dec 17, 2002 | 09:03 PM
Anuj's Avatar
Re: Re: Ebay FSTB does not fit 2002
probably for the mechanics to check out the problem
Old Dec 18, 2002 | 02:49 AM
Virus's Avatar
Re: Re: Re: Ebay FSTB does not fit 2002
Always, come here first to get answers to your problems! Only exception is if your stranded and can't get to a computer. You will pretty much find out what your problem is here.
Old Dec 18, 2002 | 07:38 PM
6SPD_HLSD's Avatar
My bar looks exactly like that and no problem.
The actual bar location can be fine tuned by pivoting it about the bolts that thread into its end. That's how I got the clearance needed.
Old Dec 18, 2002 | 08:45 PM
Maximam's Avatar
Good idea! You could use a couple washers on each bolt if necessary.
Old Dec 19, 2002 | 02:41 AM
skyjay617's Avatar
try to extend the bar a bit, until the bar is not touching the throttle body, then u r fine =)
p.s Autobacs sucks, u can tell by their ratings....lots of wrong items...i dont suggest u to buy stuff from them next time!
Hope this helps
Old Dec 19, 2002 | 04:46 AM
mrmark's Avatar
Thanks for the all the info....yes, I should have checked here first! It was the the fact that they had worked on the engine the same day that I thought for sure it was something they had screwed up.
Mark
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
DBear
Sep 14, 2015 08:33 PM
Colossus
Sep 9, 2015 05:46 AM
