RT Cat Direction???
Old Dec 19, 2002 | 04:23 PM
MichaelAE's Avatar
RT Cat Direction???
Does anybody know how to tell which direction to install the RT Cat? I remember there being a specific instruction about installing it with the label facing a specfic direction. Well, I put the gen2 Cattman Y on and removed the cat to do so...the labels on the cat have all melted off. I have been hearing a somewhat odd vibration out of the exhaust during moderate acceleration and was going to lift the car this weekend to check all the bolts down there. I thought I'd check the direction too just in case it is contributing to the vibration.
I'm guessing I would throw a code if I had the thing backwards, but just checking.
Thanks folks.
Old Dec 19, 2002 | 05:03 PM
Y2KSESteve's Avatar
Re: RT Cat Direction???
Thanks folks.
Mine went on with the sticker facing down. You should be able to see the outline of the sticker I think. When I took mine off I could still definitely tell which side had the sticker.
Old Dec 19, 2002 | 05:26 PM
MichaelAE's Avatar
Re: Re: RT Cat Direction???
I think there was a sticker on both sides...one was a warning and one was the RT logo. I'll see what I can do. Thanks.
Old Dec 19, 2002 | 05:40 PM
Y2KSESteve's Avatar
Re: Re: Re: RT Cat Direction???
My RT sticker is about an inch high and about 3½ inches wide.
Old Dec 19, 2002 | 07:58 PM
MichaelAE's Avatar
Re: Re: Re: Re: RT Cat Direction???
You da' man...thanks.
Old Dec 19, 2002 | 10:35 PM
Y2KSESteve's Avatar
Re: Re: Re: Re: Re: RT Cat Direction???
No prob...glad i could help....
Old Dec 20, 2002 | 06:37 AM
CJLax's Avatar
Re: Re: Re: Re: Re: Re: RT Cat Direction???
I just purchased this cat from e-bay and on the cat itself is a sticker which shows the direction for input output. When I get home tonight I will pm you. I'm going to install this cat this weekend. I've heard some mixed reviews however about this cat, or any cat. Good luck with the install.
Old Dec 20, 2002 | 07:24 AM
MichaelAE's Avatar
Re: Re: Re: Re: Re: Re: Re: RT Cat Direction???
I've had the RT Cat on the Maxima for several months now...with no problems...I pulled it off and reinstalled it last month while putting my second y-pipe on...that's why I can't remember which way to put it on. When you install it this weekend...can you look for any distinguishing marks which make it obvious which way to orient the cat? Other than the sticker, that is.
Old Dec 20, 2002 | 07:37 AM
UMD_MaxSE's Avatar
Got Bent?
does it really matter? As long as the arrow indicating 'flow' is pointing in the right direction, why would it matter whether you mounted it 'up' or 'down'. The only thing I can think of making a difference is the location of the heat shield. The heat shield on my RT cat fell off a long time ago anyways
maxinout93
Oct 31, 2015 02:04 AM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
