Looking for a strobe kit.
Re: Looking for a strobe kit.
Originally posted by Igor911
Hey guys, im looking to get a strobe kit. Any 1 know of a good website with many choices of kits or have any recomendations? Thanks.
I am an authorized dealer of Whelen Emergency warning products. I have some of the best deals on strobe kits you will find. I do not sell the ghetto stuff, such as PepBoy strobe bulbs, etc. E-mail me for more information. I have sold many kits on here to guys like TheBigSadler & MaximaRider.
IGOR, just so you know, I have one of these Whelen strobe kits. I have a 6 strobe controller one.
Now the pig-tail looking bulb have to have a 1" hole cut into anything you plan on putting it into. Such as the tail, need to drill that hole. The headlights, ALSO need to drill this hole. If you dont feel too protective of your headlights and drilling a hole, then no problem there.
Only reason I mention this is because alot of people dont realize they need a hole drilled that large.
Dixit
Dixit
Thanks for adding that in BigDog. I automatically assumed that he would know about the drilling of the holes in to the light's housings.
How much for a standard pigtail, no color.
Dixit
KrazyD, I broke one of my pigtail bulbs trying to get it to fit in my tailight and then when trying to put the stock bulb in I broke the whelen strobe.
Dixit
Dixit
Are you using the normal grommet type bulbs, or the flange-mount screw in type? I'm assuming that since only the bulb broke, you won't need any cable. A HA239C goes for $28 plus shipping. E-mail me for more info if you need anything..
Stop calling them pigtails! They are called strobe bulbs
Definetely the flangemount screw type. And yeah they still pigtails to me
I think im going to go with the street glow kit with changable patterns.
If you want a true kit, than unfortunately only the true Whelen ones are the way to go.
The kit i want is 90$ for 2 strobs that are xenon that come with a control modual that regulates speed and blinking patterns.
Anyways, sorry I couldn't help you..P.S. There's no such thing as a Xenon strobe
Just to let you know since you decided to go with that kit, it will in NO WAY imitate a true strobes you see on Police cars. Those kits you see for 10-40dollar range are those pencil rod style strobe units where it only blink at a constant pace of 2 flashes per second. Very slow. But if that is what you are looking for then go with that.
Stobe Question
Is it possible to wire a strobe to go off with the factory alarm? Also, do you need a 1" hole for every strobe light there is? That seems awefully big.
What I would like to do is put a strobe light say on top of the dash so it flashes in the person's eye if they are sitting in the car. Anyway to do that?
Thanks.
Thanks.
Re: Stobe Question
Thanks.
Thanks.
Re: Re: Stobe Question
It's possible to wire your strobes to do anything. You need to make a 1" hole into any lighthead where the strobe head is going to be placed into. Also, I would not recommend placing an open strobe bulbs on your dash.
They were testing the alarm the other day and all these strobes were going off and I was all "Whoa! I've gotta get these in my car!"
Also, do these work on a transformer or are they 12volt? I ask because I would like to also get these hooked up to my house alarm as well as my door bell. The house alarm would just be to freak out any would-be theives. The door bell because my home theater is so loud I would need another home theater hooked up to the door bell to hear it!
Re: Re: Re: Stobe Question
How much power do they draw? Instead of on the dash, how about above? The only strobes that I've actually seen up close is the ones that we use at work for the fire alarm. They are a bulb about 2 inches big incased in plastic. That is mounted to a red box.
did any1 install the strobes in their headlights? Im thinking of turn signals and brake lights.
If you still set on getting them, im not hating on you. Just dont want to see you disappointed by them when you actually install them and drill a hole in your lights.
I have installed them in my headlights, tails, turn signals, and brake lights on my last car. All drilled a 1" hole. But it was concealed.
Dixit
I have installed plenty of strobe kits in my time on all sorts of cars. I currently have eight in my `01, four in the front, four in the rear. I had six in my `93. The installation isn't hard at all.
I had a pain of a$$ problem trying to get the amp wire through there and catching it on the other side.
I still have my kit sitting in my room cause I dont feel like going through the pain and hassle if it wont be easy. I have 6 strobes, cant figure out where to put them. I know I can put two in my tails and then 4 up front. Like two in the headlights, and then dont know where to put the 2nd set up front.
Dixit
Question, how did you get the plug connector to get through the firewall hole? Actually the hood cable hole since that is where out hole is. Or did you drill an entirely new one. I cant even begin to think how hard it is to get the cable through that hold and out the other side on the driver's kick.
Dixit
Dixit
Installing strobes in the Maxima's HID headlights is a big pain because its housing are very curvy and it isn't very straight forward looking. The placement of the holes is difficult and usually not 100% even. I would imagine that most people who have HIDs put them in place of their high-beams or in the same reflector as them. I doubt the tubes will fit into the front turn signals or parking lights of the 2002 headlights. Truthfully, this is the main reason why I haven't upgraded to the 2002 HIDs, because I have seen no practical placement for strobes and I need them (i'm a VFF). However, I know for sure that you can fit four hide-a-ways into the rear assemblies (brakes/turns).
So BigDog, unpack those strobes and install them!
has any1 drilled through the 2k-2k1 max headlight? if so was it hard and do u have any pics? I need to make a 1/2" hole.
As for the firewall, I make my own 1.5-2" hole (depending on the amount of wires) that I run all the wiring through. It's not hard if you have a good drill and a strong hole-saw bit. I've never had a problem getting through. I wrap all my wiring up in loom when it goes through the firewall b/c that metal is extremely sharp and can splice the wires if you're not careful enough. Then I seal the hole I made with silicone so you don't hear any wind or engine noises while driving. The trick for getting the grey strobe cables through the firewall is to not put on the white connector tabs until all the wires are ran, or else they will not pass through.
I will most likely put the back in my car again. Just need time. Wish I could put two more up front, but it will be a pain no doubt. I might be removing the assembly to figure something on this one.
I just am going to hate removing them damn tails again for the 3rd time. That goop is a killer.
Dixit
I knew you drilled that hole. But the plug on my wires dont come off. They are part of the wires. Only way to get the plug off is to cut the wire and re-splice the whole deal. That is why I never bothered on atempting to remove the plug.
Dixit
Dixit
Don't take out the taillights! You don't need to take them out at all to make the holes for the bulbs. Just make the holes are close to the stock bulbs as possible and you'll be fine. The white connectors come off without a problem. You need to use a really tiny flathead screw driver and push in the little metal tabs that hold the individual wires on to the actual white pieces. If you take a look at the tabs for a while you'll see what i'm talking about. There's a little metal piece that sticks out onto the white plastic so the wire doesn't move.
Originally posted by MyownNismo
Anybody got these strobes in action like a video clip.
ok the main concern i have about drilling the head light is that when i drill all the dust and drilled peices will go inside of the headlight. Then u will be able to see the dust and crap inside the headlight. Is that true?
Dixit
Dixit
BTW: KrazyD can you post prices here or PM w/ prices on which kits you sell, i think 2 in front & 2 in back would be good enough for me
...thanks
Planning on doing something. Might have to drill to get another two in there.
