BIG Engine Problem-Need Serious Advice Gearheads
HELP!! BIG Engine Prob-Need Serious Advice, Gearheads
Broken piston rod!
Nissan showed me the engine (all apart on the service floor) and the damage the broken piston parts had caused to the cylinder #5-pretty banged up.
They are claiming I have 4 options, one is a short-block replacement, one is a long-block replacment, send out for machining, or engine swap.
I have always taken my car there and they know of my aftermarket parts, including nitrous (which I did take off before I took it in for this service). They have also turned my case over to Nissan NA to make a waranty decision-as I'm still w/ in coverage limits.
I feel I won't get warantee coverage, even though at the time of the incident, I was on the dyno and my nitrous A/F was right at stock A/F-everything was working perfectly... until SNAP! So, I really feel it was a part problem.
They have estimated $6-$8K in repairs....I can't afford that!
Any advice to help me get this fixed cheaper?
Re: HELP!! BIG Engine Prob-Need Serious Advice, Gearheads
Originally posted by Stikya
Broken piston rod!
They are claiming I have 4 options, one is a short-block replacement, one is a long-block replacment, the other is to send out for machining, or engine swap.
I have always taken my car there and they know of my aftermarket parts, including nitrous (which I did take off before I took it in for this service). They have also turned my case over to Nissan NA to make a waranty decision.
They have estimated $6-$8K in repairs....do I have any other options? I can't afford that!
Broken piston rod!
try and find an old 4th gegn VQ30DE at a junk yard???
but I don't even know of any junkyards in the KC area...
where are they?
-vq
Re: Just out of curiosity...how did u get into
Originally posted by Galo
this predicament? The bottom ends on the VQs are nearly indestructible so....what happened???????
Then as it slowed down, alot of clanking (w/in the engine) was heard.
Now I'm looking at a $7K repair bill, that Nissan is going to claim in Nitrous related, thus is not warantee covered.
Wow...dat's bad..sorry to hear that. Before
attempting to rebuild yours I would see what this web site comes up with for a used salvage engine...might be a lot cheaper...good luck
http://www.nissan-used-auto-parts.com/
Re: Wow...dat's bad..sorry to hear that. Before
And they would do the total swap for $5,200 total, $2700 for the engine, and $2500 labor.
Is this a decent deal?
Anyone know where I can get a used 2k engine for maybe cheaper?
I think the labor sounds a bit high...maybe
you can nicely ask them to double-check how many labor hours they show as being required for an engine replacement because even if their shop rate was 100 bucks an hour (which it cant be, no way) their labor quote comes out to be something in the range of 25 hours worth of work....three full days to do an engine swap?? Nahh...cant be
I would say if you can shave a 700 to a grand off the labor..get it into the range of $4000 to $4500 or so it seems like a sweet deal to me.
I think they charge u too much on parts. How about u get the parts for them to do the work?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1876121417
this may not have all the necessary parts. but 750 is still a steal.
Originally posted by UMD_MaxSE
could this be part of the reason?
http://forums.maxima.org/showthread.php?threadid=169142
Stickya, here's something that can be of interest to you:
http://forums.maxima.org/showthread....hreadid=177627
2k1 engine for sale
2k1 engine for sale
You could probably find somebody who would put the engine in cheaper than the Stealership and still do quality work. Just make sure they provide some kind of warranty.
You might also look at some junkyards here locally (there ARE some here in KC - I believe Frogs specializes in imports) or search the internet. Junkyarddog.com is a junk yard search engine.
email me if you need help finding a good reliable mechanic here in KC. I might know a few.
Seems to make a bit more sense in light of that post...
State Line Nissan
oh yeah...have you tried State Line Nissan?...there service dept seems to be the best in KC.
You're not messin with one of the McCarthy dealers are ya?
"When it ought to be...McTrucks"---that commercial is SO gay...
how about "it ought to be "McFiretrUCK you so hard you won't know what happened..."
sorry, i don't like mccarthy...darn slime *****...
and O'Neil Nissan just has a horrible location...too far off the highway, too many stoplights...unless you live next door...
I think you should be going to State Line ...if you want it done by a Nissan shop anyway...otherwise...have you heard of a little shop called "Donovan's" in Shawnee?
sorry for the JoCo reference...
but they good!
-vq
but they good!
-vq
Sounds to me like the ol' 20-1 A/F caused some serious detonation, and the dyno run just finished it off. I run a dyno for a living, and if I saw a 20-1 A/F I would end the run imediately, but even then, it's prolly too late. I would check a junkyard for a used motor, if I were you. And Andy, call me! Lets get that pig on the dyno, so we can make sure you don't blow it up
Re: Re: Wow...dat's bad..sorry to hear that. Before
Nissan just called and said they found a used 2k1 w/ 11,000 miles on it.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1876001676
or
Good luck. Peace.
From the looks of it Nissan is rapping you on labor. I don't know if nissan engines are harder to swap out than say b18 honda motors but guys in charlotte are paying 750-1500 for full motor swap labor. Doubt this is helpful but might not hurt to try some privatly owned shops and see what there labor charge is. Matt
Re: Re: Re: Re: Wow...dat's bad..sorry to hear that. Before
Originally posted by Rich96
I concur - McCarthief is nothing but a bunch of idiots.
State Line rocks.
I've gone to O'neil a few times too, they aren't bad.
State Line rocks.
We bought our Pathfinder at O'neil...but get it serviced at Stateline...
Styka..
where are you getting quoted $2000+ for labor?
-vq
Originally posted by Maximam
How do they know about your NOS?
You would think that if it was going to break it would have right then. Also none of the other pistons, cylinders, etc... showed any damage. So, that would suggest just a weak part, that finally gave out, to me.
Re: Re: Re: Re: Re: Wow...dat's bad..sorry to hear that. Before
Originally posted by VQMAN
O'neil's all right, but they can barely manage an oil change in their service department...compared w/Stateline, they are chumps....
Styka..
-vq
Styka..
-vq
Only problem is that to get the car diagnosed they had to pull the engine and it is already on the shop floor in pieces. I'd have to pay to put it back together or for someone to come get it and tow it way, including all the parts and pieces.
Luckily, they did offer me a 10% discount, as they always have on labor.
But, they said it is a 28 hour job, plus the 4 hours they spent in diagnosis and trying a top engine clean first. @ 73/hour w/ tax you got 2,500.
I'm not very happy about it but it's already there... I'm kind of sutck... what else can I do?
Styka..
-vq
Styka..
-vq
Only problem is that to get the car diagnosed they had to pull the engine and it is already on the shop floor in pieces. I'd have to pay to put it back together or for someone to come get it and tow it way, including all pieces. I feel kind of stuck there.
Luckily, they did offer me a 10% discount on labor.
Re: Re: Re: Re: Re: Re: Wow...dat's bad..sorry to hear that. Before
Jay Wolffe (formerly McCarthy) Nissan
not that they can help...but it's another place to get advice, from KC folk.
I don't think there is much you can do.
I was at MCRacing today, and the guy that did my dyno acted like you blew up your engine there. Because you were running lean a while back, and the engine finally gave out. Even though that was already fixed..is that the story? It may have been a different guy he was thinking of...
-vq
Re: Re: Re: Re: Re: Re: Re: Wow...dat's bad..sorry to hear that. Before
have you joinedhttp://www.kcmaximas.org
-vq
-vq
I did have one day, when we tried 100 shot that I ran in the 20's a/f; but we kept shutting it down, as soon as we saw this. Since then I've been running fine on a 65 shot.
Then Dec. 23rd, I was on the dyno, running fine, and SNAP!
So who knows???
To me deterioration doesn't seem logical. You would expect deterioration to affect more than 1 cylinder's parts. And I saw my engine apart, every other chamber looks great, except that one w/ the broken piston rod.
But, only GOD really knows!
Thanks to everyone for the advice.
I'm hoping this will all be resolved by Nissan and I won't have to pay. But, obviously I have my doubts.
I'm a little skeptical about buying an engine off Ebay, as I can't really tell what kind of shape it is in, or how honest the guy selling it is being. But, I'm going to look into the 2k1 I saw.
I'm under so much time pressure, to get my car back, and since it's alreay in pieces on their shop floor, I'm going to leave it at Nissan. I feel stuck there, and can't see a quick alternative. They are going to have my car done by next Wed.
Luckily, they have offered me a 10% discount on labor. Not much but it all helps!
Good news is, that in the down-time, I've sent my VB off for modding (Maximum Tuning), like I always wanted to. What's another $400 when your spending $5000.
Thanks to all for the continuing support!
Sounds like we need to put together a Maxima Dyno Day at your place. What shop is it?
Give me a call, and we'll set it up, 480-343-4293. The shop's in Mesa, off of Braodway and Center.
Hopefully, we can get a few Maximas together before a night at Firebird soon.
Hmm.....
Luckily for me, Nissan is swapping in a new engine under warranty.
Food for thought...
I don't have Nitrous or any type of forced induction by the way.
Used Engine on ebay
Check out ebay.I've seen a couple of diffrent engines for sale.Here is one.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1876787898
I think the dealer is going to overcharge you for the work. My recommendation would be to find a used engine on your own. You could probably find one for less than 2K. Typical engine swap should cost less than 1k and really more like 700-800. Then you will be out less than 3K.
I don't think I would rebuild the engine with the old block sinc you will have ongoing issues with the damaged piston (Unless you intentionally want to bore out the engine - but I know very little about this on the 3.0 liter Nissan engine.)
You could swap out the block, but then you will be re-using your old head which probably already has lots of wear and possibly damage on it from both age and your Nitrous experiments.
Your best bet is to get a certified used engine or a "factory rebuilt" engine which has a warranty and to let someone else (i.e. not the dealer) perform that work. I would only let the dealer do the work if it is all covered under warranty . . .
Also, since you are interested in improving your performance, you "might" look into getting a 2K2 or 2K3 engine and tranny and dropping that in . . . just a thought.
Good luck!
Good luck!
derekinthez
Nov 13, 2022 04:00 PM
fastcarny
Oct 6, 2015 10:42 AM
03VQMAX
Sep 5, 2015 03:47 PM
