HID H3 OEM Foglight Conversion Writeup
Okay...I have put together a writeup for a HID foglight conversion for a 2000+ Maxima using the factory OEM housing.
This writeup is based on the Phillips H3 4100k HID Conversion Kit. Other kits may be adapted very easily. Be sure to check the aiming on the fogs before taking it on the road.
5800k...6000k...8000k, my first night out literally overshadowed all other cars equiped with HID's out there. The glare from the fogs were minimal but don't flame me on the ethics of blinding other drivers, etc etc etc. Go and bark at those SUV with lights shining literally through your rear window. Other than that, have fun and let me know how it turns out for you!
Post pictures of your car's output!
The writeup is hosted at Http://66.125.192.138/images/h3.pdf
Originally posted by BigDogJonx
Very nice writeup. Excellent. If you want it hosted permanently, let me know.
Dixit
Dixit
Originally posted by maxkillz74
thanks. i plan on adding a few more touches to it. but, yeah if you want to host it i'll forward you the final writeup.
Great writeup, would you like it on vqpower.com? If you do, please email me the revision to luke@vqpower.com
Re: HID H3 OEM Foglight Conversion Writeup
I want to see how HID fogs look too
Re: Re: HID H3 OEM Foglight Conversion Writeup
Originally posted by spta97
The link is dead already? It's only been a couple of days!
Go to the Howto's
H3 HIDs
Originally posted by magnetic1
Catz also makes a H3 fog kit which has a smaller bulb than a regular H3 application. Perhaps all the dremeling is not needed w/ that kit?
I have the KOPS H3 6000K Hid kit in my fogs and there was no dremeling required.
Hmm, maybe it was just for the kit that he used.
Is the KOPS 35W or 21W?
Also looks like from the site that the (-) ground plugs directly into the OEM harness? That could be bad as the ground there is not a "good" ground....
H3 HIDS
KOPS is 35W
Could you send me a pic of the KOPS HID kit? I would be interested in other install options for future upgrades.
As far as the grounding is concerned...from my understanding, the relay has a separate low and high current circuit. The HIDs are powered using the high current path where as the low current is used to activate or deactivate the relay. the OEM harness is not taxed at all.
juice: Does the 6000k HID kit replace the stock HIDs? How much better are they?
6000k Headlights
Originally posted by Greg's2kGLE
Check out his homepage, he's got some pics up.
depends.. but usually in the mid 3000 range.
Thanks guys.
Are most of you replacing the stock HID bulbs. Most of the kits I see are much higher (6-8k) then you will have a matching problem again.
I just don't wanna get the wrong kit or spend more than I have too.
Is this writeup even available anymore? He link in the sticky takes you to an incorrect link. Plus, the link in this thread is dead. I'm trying to get my new headlights back in, but I want to put his HID kit in for my fogs first.
Update: Looks like i can use this. http://forums.maxima.org/infiniti-i3...on-sticky.html
Don't just search the org for helpful write-ups
http://www.nicoclub.com/archives/2k2...ts-to-hid.html
knight_yyz
Nov 1, 2015 01:34 PM
Calabar
Oct 5, 2015 09:57 PM
atriuum
Sep 28, 2015 01:19 PM
