How do you change headlamp bulb?
Re: How do you change headlamp bulb?
Originally posted by Scrimbo
OK, I'm dumb, but I've never done this before. How do I remove the headlamp blub so I can replace a burned out light?
CarDomain.com is down due to high traffic. Anyone else?
Originally posted by Y2KSESteve
Squeeze the outside connector part at the sides and pull back. It should come right out. Then pull out the black ring, nothing is attached to it. Then there are two little metal bars holding in the bulb. Squeeze the bars towards each other and they should come loose. Then pull out the bulb! (in a nutshell) Hope it makes sense.
I'll give it a shot here in a bit. I just got back from driving around, so I'll let the car cool down a bit before I go sticking my hands in a hot engine compartment.
Do this first, unplug the wiring harness...
then the rubber boot,
then the wire retainer
I tried installing new bulbs in Bernie's 2000 SE and did not do so and it took forever.
AaronL
Nov 15, 2020 11:52 AM
JoshG
51
Sep 21, 2015 10:41 PM
How old are you? I got my car used and it didnt have one. Am I 5 too then?
