19 X 8 wheels
Old Jan 14, 2003 | 04:35 AM
De Max's Avatar
19 X 8 wheels
Will 19 X 8's fit on Maxima???
Old Jan 14, 2003 | 05:36 AM
GaMax97GLE's Avatar
Re: 19 X 8 wheels
Originally posted by De Max
Wills 19 X 8's fit on 2003 stock Maxima???
Yes
Old Jan 14, 2003 | 05:46 AM
De Max's Avatar
Re: Re: 19 X 8 wheels
Originally posted by GaMax97GLE
Yes
thanks
Old Jan 14, 2003 | 06:00 AM
T-bone's Avatar
Re: 19 X 8 wheels
Check out Kloogy's car.
Old Jan 14, 2003 | 07:12 AM
cwally's Avatar
He has 8.5 I have 19x8.
Old Jan 14, 2003 | 07:22 AM
De Max's Avatar
Re: Re: Re: 19 X 8 wheels
what about 19 X 9??
Old Jan 14, 2003 | 11:41 AM
PoweredbyNissan
What is the offset on your 19x8 wheel? and your tire size?
Old Jan 15, 2003 | 02:04 AM
De Max's Avatar
Re: Re: Re: Re: 19 X 8 wheels
I don't know yet, but what would be a good offset(5x100, 5x114.3, 5x112, 5x120???) on 03 Maxima and a good tire size(225/35/19)??? Don't know too much about rims and tires...
Old Jan 15, 2003 | 02:40 AM
Hobert's Avatar
Re: Re: Re: Re: Re: 19 X 8 wheels
5x114.3 is our bolt pattern, not offset. I am not sure what offset would be best for whatver width you decide to get.
Old Jan 15, 2003 | 02:52 AM
De Max's Avatar
Re: Re: Re: Re: Re: Re: 19 X 8 wheels
cool thanks
Old Jan 15, 2003 | 05:05 AM
Blackgums100's Avatar
Use the search function, numerous members have 18, 19, and even a couple of 20's.
Whatever you do make sure you do not buy 225's, that is way to narrow, a 245 would be better.
Old Jan 15, 2003 | 05:09 AM
De Max's Avatar
thanks
Old Jan 15, 2003 | 08:59 AM
Max280's Avatar
245s will fit on the 19X8 rims. i have supperlegaras, OZ 19X8 and so3 tires, 245.
Old Jan 15, 2003 | 09:03 AM
cwally's Avatar
I have 35MM offset. I am running 245/35-19 Nittos on my wheels.
Old Jan 15, 2003 | 03:03 PM
Tripower's Avatar
How do you like the S-03's? (Bridgestone's, right?)
Old Jan 15, 2003 | 05:56 PM
max'n out's Avatar
I'd go 19x 9 witha 255-35 with around a 40mm offset.
Old Jan 15, 2003 | 07:03 PM
Max280's Avatar
The bridgestones are really nice. very good traction, even on the wet roads.... 19X9s fit on a max!? wow. can someone please confirm this.... i'm thinking of getting new rims... which means the superleggaras are for sell. if you're interested, please let me know harry280@aol.com
Old Jan 15, 2003 | 07:31 PM
max'n out's Avatar
Yes with the right offset they fit. I have seen a 265 tire run on a max. So yes it fits. Just get the right offset.
Old Jan 15, 2003 | 11:07 PM
KLOOGY's Avatar
L33t BMW Drivah
I am looking to upgrade to 255's . The 245's I have look to narrow for my 8.5 inch wide wheel... we will see ...
Old Jan 16, 2003 | 09:09 AM
max'n out's Avatar
I"m doing the same thing as soon as mine are done, 255-35-19 michealn pilot sports.
Old Jan 16, 2003 | 02:50 PM
Tripower's Avatar
What offset would you go with for an 8" wide rim? Also 40mm? Thanks.
Old Jan 16, 2003 | 04:14 PM
max'n out's Avatar
Depends on what wheel your looking at, not all come with the same offset, personally I like the look of the 37-40 range but anything within 35-40 should work pretty easy,. without becoming ghetoo.
Old Jan 16, 2003 | 05:18 PM
busakiller's Avatar
Kloogy... Will 255 fit without rubbing?? And another question.. How much of a drop do you have?? Do you have the stock struts??
Old Jan 17, 2003 | 09:53 AM
PoweredbyNissan
What kind of offset would make the wheel go away from the body of the car? higher or lower?
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
