b\m slick shift?
Old Jan 21, 2003 | 08:47 AM
maxgsxr1
b\m slick shift?
anyone try this fluid in their automatic? thinking about trying it for a tighter-crisper shift. what do you guys think?
Old Jan 21, 2003 | 09:35 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Re: b\m slick shift?
im about to do the drain and refill routine before this sunday and im replacing mine with mobil 1. mainly because of availbility of its 5 bucks a quart. i worked at advance auto for just over a year and not once did i sell any of the b&m. not to say its good, its just not as popular i guess.
Old Jan 21, 2003 | 09:01 PM
maxgsxr1
Old Jan 22, 2003 | 07:55 AM
iwannabmw's Avatar
Cliffnotes: It's safer to stick with a know quantity. I.E. Amsoil, Mobil 1 or Redline.
Old Jan 22, 2003 | 07:40 PM
02MaXiMa_GLE's Avatar
Or... you can be an "explorer" like Columbus & "discover" on your own what works best for you.
I say go for it! Just make sure it's a Dexron Type III grade fluid.
I use Royal Purple products & love them. But they are costly at $6-7/qt.
G
Old Jan 22, 2003 | 08:09 PM
LOOKS LIKE YOU CAN'T USE IT IN YOUR MAX! PRE-1998 TRANNYS ONLY!
I got this from JEGS.COM
Ideal for racing, performance street, RV and heavy duty applications.
Not an additive!
Works with all transmissions when a firmer shift is desired on 1997 and earlier vehicles. Not recommended for 1998 & newer applications.
B&M Trick Shift Performance Automatic Transmssion Fluid (ATF) is the easiest way to firm up your transmission's shift performance. Not an additive, this safe and effective blend of extreme pressure agents and foam inhibitors will provide a noticeable shift improvement when you replace your existing automatic transmission fluid with Trick Shift. Ideal for street use aand high load applications such as racing, off-road, towing and heavy duty fleet use. Trick Shift may be mixed with other types of ATF but works best by itself. With B&M Trick Shift you can literally ''pour in performance''. Meets or exceeds Type F requirements.
In case you were wondering, I noticed an immediate improvement with Royal Purple @ 15,000mile fluid-change.
G
Old Jan 22, 2003 | 08:29 PM
iwannabmw's Avatar
[/B]
That's not a good sign.
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
