Problems accelerating, codes?
Old Jan 29, 2003 | 08:22 AM
Helmut Terjung's Avatar
I just bought a used 2000 5-sp Max with 68k miles on it. It has one strange problem... when accelerating it does fine until it hits 3,500 RPM, then basically hiccups/stalls and is very reluctant to rev higher within the RPM range.... Anyone has had any similar problems? Ideas where to look?
I was going to check whether there were any diagnostic codes but the set-up seems different from the 4th gen Maxes even though my Haynes Manual tells me that's not the case. Can someone tell me how I extract the codes?
Thanks much for any help you can offer!
Old Jan 29, 2003 | 09:21 AM
PCGuRu2K's Avatar
Re: Problems accelerating, codes?
You a Service Engine Soon light or anything? If not you'd probably won't be able to pull any codes down. Did you tune up the car yet?
Old Jan 29, 2003 | 09:51 AM
Re: Re: Problems accelerating, codes?
No, nothing is on, it runs fine, gets good gas mileage otherwise. Air filter is new, spark plugs decent, fuel filter I'll replace soon but I doubt it's that. No pinging as far as I can tell.
Since there is so much electronic "junk" on the car I figured it can't hurt to check the codes. My 1995 never showed anything and then I pulled the codes, which told me that the TPS was on the fritz. It did have a little bit of a hesitation throughout, that's why I checked....
Old Jan 29, 2003 | 11:07 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i dont have a 5spd, but i remember a tsb about a fuel cut off. maybe its not getting enough fuel. it should still be up in the tsb sticky at the top of the page.
Old Jan 29, 2003 | 11:33 AM
Thanks, I'll take a look....
Old Jan 29, 2003 | 12:13 PM
N1sMO's Avatar
Try to swap out your Mass Air Flow sensor with another Maxima and see what happens. I had some hesitation and my car was running lean... I swapped the MAF from a Sentra 2.5 LE and my car got its ***** back. I have since replaced my MAF and the car runs like it never has before... I think my MAF was bad right off the production line. I am scratching the tires like a **** going into 2nd gear now... And this is with 18" and relatively new tires
BTW.. My car didn't throw any codes either...
Old Jan 30, 2003 | 05:37 AM
Thanks for your info. I'll try this but I'd still like to find out how to extract the codes in the first place.... Anyone know how to do this?
Mar 12, 2020 12:06 AM
Steven Orozco
Sep 12, 2015 10:41 PM
jcvgn
Sep 10, 2015 08:03 PM
jwright36
Sep 8, 2015 11:45 AM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
