car feels sluggish...
Old Jan 31, 2003 | 10:55 PM
SoloMaxima
my poor Maxine feels so slow these past few days....i don't know why...can it be the tranny slipping..??
i did a search but i have no idea what really is causing this...
Old Jan 31, 2003 | 11:25 PM
RBa's Avatar
RBa
Re: car feels sluggish...
Time to get your fuel injection system flushed & cleaned..
Old Feb 1, 2003 | 09:29 AM
foodmanry's Avatar
Da Roller Coaster!
How many miles do you have on your car? It may be time to change the spark plugs as well. I just changed mine at 53K and it made a world of difference. The enginer is quieter, smoother, and has more pull. My original plugs were pretty much fried when I changed them. Platinum for 100k miles HA! Yeah right... I went with the new iridium plugs.
Old Feb 1, 2003 | 10:06 AM
SoloMaxima
is it hard to do the fuel injection flush yourself..?? if now how much does usually cost..??
i only got 27,000 miles....can it be the spark plugs..??...how do you change the spark plugs on the maxima..?
Old Feb 1, 2003 | 10:33 AM
foodmanry's Avatar
Da Roller Coaster!
Piece of cake! Just get a bottleo of fuel system cleaner or fuel injector cleaner and pour all of it in your empty fuel tank. Fill up with gas and it should do the job within one tank. Some of the brands noted on here have been CD2, Red Line, and some others.
i only got 27,000 miles....can it be the spark plugs..??...how do you change the spark plugs on the maxima..? [/B][/QUOTE]
Do a search. Someone just wrote up a how to, I think it was SprintMax. But go with the injector cleaner first and see if that clears up the problem. Your plugs should be ok after 27,000 miles unless you are running really rich and they are fouled.
Old Feb 1, 2003 | 10:42 AM
RBa's Avatar
RBa
Do a search. Someone just wrote up a how to, I think it was SprintMax. But go with the injector cleaner first and see if that clears up the problem. Your plugs should be ok after 27,000 miles unless you are running really rich and they are fouled. [/B][/QUOTE]
Take it to a shop!!!!!!!! Those bottles only do so much.. You need to clean out your throttlebody, fuel injection system and perform other minor maintainence needed when nearing 30k..
Spark plugs are located under the plastic valve cover-cover and behind the intake manifold... It's a bish to change the rear ones...
Old Feb 1, 2003 | 11:04 AM
foodmanry's Avatar
Da Roller Coaster!
Easy...easy....you do not need to take it to a shop just yet. Most shops will just pour a bottle of the fuel injector cleaner in your tank and call it a "fuel injection cleaning special" anyhow. So start with that yourself and if your car is still sluggish you may need to clean the throttle body as mentioned, but that is doubtful at 27K miles.
They are not that difficult with the correct tools.
1. Spark plug socket
2. Extension pieces (ideally having a wobble end type)
3. Torque wrench (necessity! the aluminum head is oh so soft!)
4. 10 mm socket for the ignition coil pack bolts.
Having small hands also help!
Old Feb 1, 2003 | 12:48 PM
SoloMaxima
thanx...i'm gonna try the fuel injector cleaner first...have you try any specific brands before..??
Old Feb 1, 2003 | 01:33 PM
foodmanry's Avatar
Da Roller Coaster!
STP, CD2, and Red Line. All pretty much the same. STP and CD2 are one time dump in the tank. Red Line can be a one time dump, and/or an ongoing cleaning using a lesser amount.
Old Feb 2, 2003 | 01:22 AM
SoloMaxima
how's the penzoil brand..?
Old Feb 2, 2003 | 05:12 AM
98maxsel's Avatar
yea,,, try the fuel injection treatment at a local jiffy lube.
Old Feb 5, 2003 | 09:51 PM
02MaximaSE's Avatar
solo, did you do the fuel system clean?
How does the car feel now??
I have 27K miles now and It really does feel a bit sluggish now
Have you changed your plugs also? Tell me how it turns out... thanks
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
MikesChevelle
Aug 14, 2015 12:31 PM
Trin1j23
Aug 12, 2015 08:31 PM
