AFR a bit lean...
AFR a bit lean...
We had a local maxima dyno session today... Big thanks to BigDogJonx and SRT (the shop) for setting it up and organizing it... Anyhow, we all got our air/fuel ratios measured. It seemed that we were all running a bit lean since we all had AFRs in the 14-14.5 range. My AFR was flat throughout, but it was above 14... Any ideas as to why it could be lean? I used some fuel injector cleaner about 3000 miles ago, so injectors should be clean. The other thing I was thinking of was the fuel filter... sucks that ours is in the tank, or else I would have swapped that out. Any other suggestions?
Also, has anyone else get their AFR measured while on a dyno? BTW, this was on a 2k auto with midpipe/Apexi filter, Cattman y-pipe, RT cat, and UDP. Thanks!
Originally posted by Maximam
Well if you go richer you will most likely loose power. Was it detonating?
I was just thinking that I should be more around 13-14 rather than consistently above 14. Oh well... numbers were decent I guess....
180 hp
191 tq
IMHO, I think their oxygen sniffer is wrong. It's really hard for a N/A car with only the basic bolt-ons to run that lean. Plus, you said ALL OF YOU were running that lean. I think that's pretty unlikely. All the N/A Maxima dynoes I've seen are around 12.0-12.5:1
hmmm... I always thought that around 12-13 was normal...
As for the sensor they were using, I don't think it was off. A stock auto Acura TL-S dyno'd as well and the AFR was dead on around 12.1 for the whole run. He pulled 199 hp and around 180 torque.
after looking at my AF plot carefully using the dynojet viewer, it is only above 14 between 3800 rpm and 5000 rpm. It is at 14 at 5000 rpm and decreases linearly down to around 13.5 at fuel cutoff. So it's not as high as I originally thought...
Originally posted by Y2KevSE
So SRT is building Dixit's turbo...
That's a good amount of torque you have.
I'll let Dixit tell you about the turbo setup he is going with...
SRT is Lexus only for now... we should try and get them to make Nissan parts... their stuff is top notch...
The torque was pretty good... more than I expected... but I need to understand this AFR...
But sounds fishy to me. Nice numbers, BTW
Re: Perfectly stoichiometric A/F ratio is 14.7,
Originally posted by Galo
why do you think that between 14 and 14.5 is lean? That's perfect, IMHO.
Nevertheless, your power numbers are normal and decent. Don't worry about anything; you won't blow your motor.
Re: Re: Perfectly stoichiometric A/F ratio is 14.7,
Well normally close to stoich is okay. But on the dyno, you are running WOT correct? If you are running that close to stoich at WOT, I "might" be worried. Becuase the ecu runs a closed loop program that is richer than the normal open loop ( 02 ) program.
Although, I think your car is running fine, I would look into your fuel pressures or maybe your fuel pressure regulator. If your fuel pressure is a low, it "might" cause a lean(er) condition.
Apr 16, 2020 05:15 AM
Unclejunebug
Apr 2, 2016 05:42 AM
mclasser
Sep 24, 2015 11:57 PM
