Dash lights not working
Old Feb 6, 2003 | 06:38 PM
PHATMAN5050's Avatar
I installed a cd deck in my car today, and everything seemed to go well until the sun set and I realized I couldn't see my speedometer! I've checked all the connects behind the radio where it connects to my wiring harness, and double-checked to see if all the plastic connectors were in tight, and they were, and yet still no lights. I also looked in the fuse panel and practically checked every fuse to make sure none were blown. Any ideas?!
Old Feb 6, 2003 | 06:47 PM
spta97's Avatar
Re: Dash lights not working
Since you didn't mention it, did you check the brightness control for the dash lights? If that's ok, are you sure that the dimmer wire on your radio (usually orange) is hooked up to the correct wire on the harness? One other thing, did you also check the fuses under the hood?
Old Feb 6, 2003 | 06:51 PM
I dont have the orange wires hooked up to anything, because I didnt see any that matched...
Old Feb 6, 2003 | 06:56 PM
Ok, the orange wires say 'illumination' on them, but what are they supposed to be hooked up to? All the other colors are being used...
Old Feb 6, 2003 | 07:06 PM
spta97's Avatar
Did you use an aftermarket harness to plug into your factory harness? If so, the wires are labled (and pretty much standard colors for all radios) so you just wire the aftermarket radio wires to the harness and then the harness plugs in to the factory one.
Not connecting it would not be a problem, the problem would be if you connected the wrong wire (like a power wire) to the factory wire for dim control. I'm speaking from cars in general but I'm 95% sure that the Max had a dimmer when I installed my stereo in it.
Old Feb 6, 2003 | 07:23 PM
releasedtruth's Avatar
rilla dope
Yeah, miswiring may be the culprit. I soldered mine when I did it, but I guess I managed to get em right. Check the harness and make sure you didn't accidentally disconnect anything when you were pulling and pushing. That happens a lot too
Old Feb 6, 2003 | 09:42 PM
I found it. The fuse is under the hood and is called 'Tail Lamps'. Go figure...
Old Feb 6, 2003 | 09:50 PM
BigDogJonx's Avatar
Yall are ALLLLLLLLL wrong.
It is the taillamp fuse. It controls the illumination once he shorted it out, he shorted out the taillamp fuse.
Old Feb 6, 2003 | 11:43 PM
vsmax's Avatar
Dixit,
i must say...you prolly are the man on the whole org!!!
you seriously kick a$$!!!
Old Feb 7, 2003 | 01:27 AM
BigDogJonx's Avatar
Originally posted by vsmax
Dixit,
Im just a freagin PEON on this org that gets no respect.
Old Feb 7, 2003 | 03:43 AM
ToYLeT902's Avatar
JET Speed Lab
what fuse is for the clock and tripometer?
Old Feb 7, 2003 | 05:28 AM
spta97's Avatar
Originally posted by spta97
"....One other thing, did you also check the fuses under the hood?....."
I was close!
Old Feb 7, 2003 | 01:35 PM
BigDogJonx's Avatar
Clock is Fuse # 12
Tripmeter is Fuse # 12 and #30
Old Feb 9, 2003 | 10:35 AM
ToYLeT902's Avatar
JET Speed Lab
Clock is Fuse # 12
where would these fuse's be located?
Old Feb 9, 2003 | 12:31 PM
BigDogJonx's Avatar
Drivers left kick panel inside.
The numbers goes like this.
Dixit
King_Ten_Ahead
Sep 30, 2015 04:27 PM
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
kenc15
Aug 5, 2015 08:29 AM
