Brake Questions...
Old Jan 8, 2001 | 06:55 PM
SFMax20SE's Avatar
Hey Gang,
It's me again... newbie in SF
Want to upgrade my brakes... was wondering what you all recommend? The Brembo kit? Or other brand?
If I intend to go fast, need to stop fast too!
Old Jan 8, 2001 | 07:38 PM
mdeal's Avatar
I believe you have a couple of choices: (a) big brake kit (b) after-market, drilled or slotted rotors, through Stillen (Brembo makes the core, Stillen drills or slots them).
The only performance oriented after-markets pads, for non-big brake kits I know of, are Axxis pads.
I could be wrong.
Hey, Got Rice?! (<- parts guy) Do you know of other options?
Old Jan 8, 2001 | 10:36 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
SFMax20SE: I'm from SF too!
Stillen rotors or pads have 4th gen specs. If you install both the pads and rotors together, Stillen said there would be no problems. If you install either one, then I don't know what would happen. Our rotors are thicker than the 4th gen rotors...
Old Jan 9, 2001 | 08:18 AM
nm's Avatar
nm
Does anyone know the prices/places to buy the stillen cross-drilled rotors (front and rear), I'm thinking of getting them an I want to know my options?
Old Jan 9, 2001 | 09:22 AM
Y2KevSE's Avatar
Cheapest prices I've seen are from Avalon Racing, but you might want to check with Got Rice? to see how much he's charging also. Don't buy directly from Stillen because it's <b>way</b> more expensive.
Last I've heard, the rotors and pads were on back order...
Old Jan 9, 2001 | 07:38 PM
mdeal's Avatar
Last I heard, Avalon Racing had the rotors and pads available. Not sure about Got Rice?.
Old Jan 10, 2001 | 12:18 PM
MrBurner's Avatar
anyone know the specs on these? i'd be interested on stock 60-0 vs. new cross drilled rotors vs. stock rotors w/ new pads vs. new pads and new rotors vs. brembo big brake kit...
Old Jan 11, 2001 | 11:21 AM
wdave's Avatar
60 - 0 is going to be the same no matter which brakes you use - the first few stops. Fancy brakes will only help if you are in a situation where you might overheat the stock brakes under repeated use. As long as the brakes have enough stopping power to lock the wheels and activate the ABS the tires will be the main limiting factor. The real racers who use drilled rotors primarily do so for weight savings, not cooling. The penalty is pad wear (hold your pad against a cheese grater) and premature rotor cracking. The slots are to remove the boundary layer of molten and vaporized pad material for better grip under severe use.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
