Bore/Stroke 3.5L
Old Feb 21, 2003 | 06:49 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
Bore/Stroke 3.5L
What in the world are the engine specs? I've looked all over the internet and on here, but my search wording must be a bit too narrow. My questions is what are the bore and stroke dimensions of the VQ35DE, along with the compression ratio and approximate CFM airflow. I'm building one on the Dyno2000 Engine Simulator, just to check the approximate HP differences between minor mods. Any and all help would be greatly appreciated. Thanks!
Old Feb 21, 2003 | 07:25 AM
OT n00bs FTMFCSL
Still no luck. As far as I can guess, it's got to be around 3.75 x 3.25...somewhere around there. Also, the CFM is really important. Anyone? Buhler? Buhler? Buhler?
Old Feb 21, 2003 | 07:30 AM
Y2K2Driver's Avatar
I can get those numbers for you when I get back from work as I'm pretty sure they are in the ESM, that is if someone doesn't post them before then.
Old Feb 21, 2003 | 07:50 AM
DAVEB's Avatar
Re: Bore/Stroke 3.5L
95.5MM X 81.4MM
Old Feb 21, 2003 | 07:58 AM
OT n00bs FTMFCSL
How about the maximum stock CFM? That's a hard one
I need the cam specs and the transmission ratios as well Can't find that anywhere either. I thought this info would have been easier to find than this ...
Old Feb 23, 2003 | 11:21 AM
OT n00bs FTMFCSL
Bump. Need valve sizes as well Please help me out here...found some stuff, but not enough...
Mahmuth
Sep 17, 2015 11:45 AM
soloist3
29
Sep 1, 2015 03:47 PM
95naSTA
Aug 16, 2015 05:03 PM
95naSTA
Aug 16, 2015 05:02 PM
Mike S.
Mar 16, 2001 05:53 AM
