pot hole
pot hole
Hey folks!
I hit a nasty pothole this morning going to work (2k3 only 1400 miles
) Driver's side, front and back took the hit.
I can see scuff marks on the sidewalls. The rims are fine. The tires didn't blister.
When I go onto the highway, from about 50 - 65, I felt a slight vibration. It sorta went away for a bit and comes and goes. The frequency feels higher than an unbalanced tire.
I'm going to try rotating the tires tonight, see if that helps.
I'm worried that I damamged the wheel bearing or bent something. (car doesn't pull)
It's been a brutal winter, my other car was almost totaled, now this.
If anyone has any ideas on what I might have done I sure would apprecaite the help...
) Driver's side, front and back took the hit.I can see scuff marks on the sidewalls. The rims are fine. The tires didn't blister.
Re: pot hole
Originally posted by itdood
Hey folks!
Hey folks!
Sorry, had to vent a little there.
Re: pot hole
Hey folks!
Hey folks!
Hopefully no other damage. But I am replacing all 4 tires now. I was going to do it this summer but I can't wait that long now.
Re: pot hole
Hey folks!
Hey folks!
What you may have done is 'throw a belt' or otherwise bend/damage the structure inside the tire. While this may not actually change the balance of the tire, it can often be enough to cause vibrations.
Re: pot hole
Hey folks!
Hey folks!
this past sat. i hit this huge pothole also and i scraped a little under my car....
sux..
Originally posted by Igor911
I just came back from the tire place. It turns out there are 2 bubbles in my sidewalls on both from tires and they said that i need new tires
WTF I just bought these brand new like 6 months ago
Re: pot hole
Hey folks!
Hey folks!
) Driver's side, front and back took the hit.Not that this might help as it seems the size of the pot hole is bigger than any tire can handle.
Tough break!
Thanks for the all replies folks!
I was talking to a bud who used to run a NTB store. He said the same things mentioned here. I either killed a belt or two, or I may have thrown a weight off the rim. I have the TE rims, but from what I see, the weight is still on there. I don't see any hint of one missing.
This guy doesn't think I damaged suspension because I don't pull. SoloMaxima, I didn't scrape, although I did knock some fillings out of my teeth
It was a nasty hit.
The tire didn't blister (yet), but I think I may have damaged some belts, I can see a scuff mark on the sidewall. The last time I had one of those the tire did blister, so I'm definitely rotating it to the back tonight until I see what happens to it.
I'm honestly shocked that I didn't get a flat or bend a rim, it felt that bad.
It really is a bummer on such a new car. It doesn't feel new anymore (in my head).
We haven't had a season this bad in 5 or 6 years in the Philly area, I forgot what it was like.
Good luck guys, and watch out for the holes!!!!!
It was a nasty hit.
Re: Re: pot hole
Originally posted by vito1281
I can definitely see where you're coming from. Although I haven't hit any significant ones yet (and hopefully won't), driving right now is like a damn challenge course, trying to avoid all the potholes.
DC_Juggernaut
Sep 28, 2015 04:07 PM
max ride 41
Sep 17, 2015 06:17 PM
bbsitum
Sep 11, 2015 04:55 PM
