Tok front and AGX rear
Old Feb 25, 2003 | 10:37 AM
djPlayboy's Avatar
Does anyone have this strut shock setup??? Im wanting to do this setup but i cant decide what springs to go with. I dont want a ride that is way to bouncy and not way to harsh. I know changing to new shocks and spring WILL make the ride harsher but i dont want bouncy, like on a friend of mines GCs. If anyof you guys have the tok agx combo please post what the ride is like... Any help is appreciated.
DJ
Old Feb 25, 2003 | 12:31 PM
[maxi-overdose]'s Avatar
I wont mix struts. the lowest setting on the AGX is still stiffer than that of the tokicos. so the front will always be softer than the back (bouncier) and it makes the ride funny.
AGX with H&R seems to be a good combo
Eibach might have problem fitting onto rear AGX strut. Deven2k uses 4th gen Eibach rear spring to have a better fit.
for more info. try a searh on my name and Deven2k. we had a long chat on this topic. I wanted to mix struts before and it was not recommanded. I now have Koni and eibach.
Old Feb 25, 2003 | 12:34 PM
djPlayboy's Avatar
thanks for that info, i thought i read somewhere, where someone did that
whats the ride like on the konis, also whats the price compared to the agx's
Old Feb 25, 2003 | 12:52 PM
no problem. The ride quality with Koni and Eibach is acceptable for me. It's a bit stiff but I dont have any problem with that. Brand new konis are ranged from $450 - 520. (that's for 4th gen applicationg, 5th gen is coming out soon) where the AGX is around $380. I will recommand AGX....I choose Koni because I already bought the eibach.
Old Feb 25, 2003 | 01:00 PM
djPlayboy's Avatar
i was use to the stiff suspension on my svt i had this shouldnt be any different, i may just go agx all around, now what springs do i want...lol. Im thinking H&R but i dont want my rear sagging, maxspeeds are cheap, eibachs are stiff, GCs way to stiff.
<~can't make up mind
Old Feb 25, 2003 | 01:29 PM
HitManSE's Avatar
Progress? Its not too stiff, nor do they sag. Or sprint, they're suppost to be stiff but people around here say its near stock ride but they do have stock struts. Im personally leaning toward the AGX/Progress combo. ASU174 has that combo and the ride in his car isnt too bad at all.
Old Feb 25, 2003 | 03:08 PM
WildmanAL's Avatar
I second that AGX/Progress combo
Old Feb 25, 2003 | 04:42 PM
costcowholesale's Avatar
4th gen & 5th gen uses different springs?
Old Feb 25, 2003 | 04:55 PM
for eibach....yes.
Old Feb 25, 2003 | 04:56 PM
for eibach....yes.
do you know what the difference are?
Old Feb 25, 2003 | 05:04 PM
Jeff K's Avatar
I have this setup..>
I running the exact setup that your talking about and love it. I'm on H&R springs and that's seems to be the spring that will give you a close to factory ride but without the bounce. I've been on this setup for close to 20,000 miles. I choose the Tokico fronts because Cattman was talking so long to getting the KYBs modified.
So I was sick of the car bouncing and decided to run Tokico front struts for $90ea and the rears are KYB adjustables(set on #2) for $80 and the H&Rs were around $220. So for my complete setup I was looking at $600 shipped and the car had a nice 1.5" drop to boot. Tokico rears shocks are the worst so after talking to Cattman and finding out that they don't alter the 4th gen KYBs it was a done deal. The Cattman modified shocks are about $145ea(I think). Saved over $100 bucks by doing this and maybe more because I didn't have to buy the 4th gen mounts.
MaxSpeed springs sag and Eibach are very firm.
Good luck on your choice.
Old Feb 25, 2003 | 05:38 PM
not sure about the front spring.
the 4th gen rear springs fit better with the AGX perch of the rear strut. 5th gen rear eibach is a little narrow and it doesnt sit into the perch of AGX all the way. This may cause alignment problem.
Cattman modified the front AGX to fit with 5th gen and they use H&R spring to test it. The car weight will force the H&R spring sit into the perch. But they didnt test it on eibach and Deven2k just had a bad time with eibach and rear AGX struts.
Old Feb 25, 2003 | 05:39 PM
uh oh.. I have 5th gen H&R sitting in my closet now, I hope it'll fit (getting AGX too)
Old Feb 25, 2003 | 05:40 PM
djPlayboy's Avatar
are you all saying the agx/H&R is a good combo??? or the agx/progress
Old Feb 25, 2003 | 06:12 PM
HitManSE's Avatar
Progress will cost u about $50-60 less then H&R and will drop the car about .2-.3" more then the H&R will while still giving u a decent ride (I personally like it) I dont however have anything against the H&R setup, it just doesnt drop the car as much from what I know, costs more and ive heard the car rides near stock but have not driven a car with the H&R. Its ur call man, im leaning toward the Progress setup.
Old Feb 25, 2003 | 07:34 PM
hmmm...how come you are getting 5th gen spring for your 4th gen?
the part no. is different.
Progress has the same spring for both 4th and 5th gen.
Old Feb 25, 2003 | 07:38 PM
I got them used for really cheap the guy said it'll fit
Old Feb 25, 2003 | 08:00 PM
ic....that's not too bad then. if it doesnt fit, I bet there will be a list of people who will be interested in getting your spring.
Old Feb 26, 2003 | 03:15 PM
djPlayboy's Avatar
ill buy em for a dollar
Old Mar 2, 2003 | 12:57 PM
djPlayboy's Avatar
ok ppl iv decided to go with the GR2s and Eibachs and im ordering as soon as tax refund comes in
Old Mar 2, 2003 | 02:31 PM
WildmanAL's Avatar
Where are you planning on getting your GR2s? I'm planning on ordering these sometime early this week. Did you choose Eibach over Maxspeed because of the warranty and name? They both lower the same and I think Maxspeeds are slightly softer plus the $100 difference. I'm planning on getting Maxspeeds with the GR2s. Are you using your factory dustboots or are you buying new ones and where are you getting these from?
Old Mar 2, 2003 | 02:36 PM
djPlayboy's Avatar
Im ordering the GR2s from tirerack 95 each for the fronts and 59 each for the rears. Im sticking withthe eibachs mainly because of the warranty. and Ill proly just use my dust boots that are already on the car, there still in good condition.
Old Mar 2, 2003 | 02:51 PM
WildmanAL's Avatar
I'm calling Tire Rack tomorrow
Old Mar 2, 2003 | 03:02 PM
djPlayboy's Avatar
<~calling as soon as tax refund comes in
Matt93SE
May 24, 2019 02:58 PM
Devo
18
Mar 7, 2016 07:36 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
Huttig2009
Sep 25, 2015 03:31 PM
laparka66
Aug 6, 2015 09:36 AM
