Ground Control Coilover
I want to know how come the Ground Control coilover cant lower more.. I twist the front perch all the way down and the rims wont tuck under the fender.. The rear does but not the front.. Hmm does anyone know what the Coilover number on the spring that show which one goes to the front and the rear.. Contach with me if you had experience use Ground Control Coilover.. Thanks
Originally posted by SE7EN
Should I heat up the Eibach front Spring to lower more.. I love the way the front tires tuck under the fender.. LEt me know is it a good idea or not?
I know exactly what your talking about seven. After i lowered my car on my GC's, the front still has about 1 inch of a gap. I wanted to slam it and loose the gap, to give it a really clean tucked look. But i dont know what to do. I heard heating the spring is much worse than cutting it, i don't know though. But the two choices are tow cut the spring or heat it. I heard the spring gets really messed up when heating cause the compression in certain areas will be different. I just lived with it and raised the back a little to make it even....
I dunno about you guys but I lowered it about a third of it's setting and I have a pinky wheel gap in the front and none in the rear.. I can still go lower so they tuck in.. I'm gonna try and lower it all the way when the weather gets warmer and I find a set of allenkeys that fit..
Originally posted by Y2KevSE
Get shorter springs from GC. Sounds like you have 8" springs (I had 6" springs).
hey kev how low did you have your gc's set???...looking at ur car and my car..i think i am about as low as you....you have the 245/40/18 tires and i have 225/40/18 tires....so u have a little less wheel gap because ur tires are bigger....but i "think" we are about the same height off the ground....
ALSO..kev..do you have pics of your car with the JIC's on...id love to see it!..
It was pretty low. The rear tires were tucked in and the front tires either had 1/2 finger gap or no finger gap... I don't remember.
I'll take some pics this weekend at our NorCal meet. The car is higher with the JIC's (my choice)... 1 finger gap for both front and rear.
Kev,
WHere should I get 6" spring from? What about I cut the coil and see how it look? What you think? Thanks for advice from you guys and I understand about the heating and cutting but how come it doesnt look low enough.. Oh well give me some advice..
Kev,
Kev,
I wouldn't cut a coil since the springs are flat at the ends.
you dont reall yneed 6 inch springs.....
cuz 6 inch springs are too low, when u want it higher for the winter or other purposes, the car wont go high...
i got 7 inch springs and the car goes really low... i have both front and rear wheels tucked under the fender...
KEv,
Where I can buy 6" Coil Spring? I really want it so bad and if you have it let me know.. Help me looking for 6" spring! Thanks for reply..
A33,
Where you get the spring? Please email me back.. Thanks
A33,
KEv,
A33,
KEv,
A33,
I did went to Ground Control website and it doesnt show the email address that I can email them to see if they do it for me.. I found the phone number but Im deaf.. I used hearing aid and cant hear the phone clearly.. Would you guys can help me to find out if they can get 6" spring for me.. Thanks
Nope, I don't work at Southwest Autoworks.
Sorry, but I don't feel comfortable ordering stuff for people. Do you have a friend or family member that is able to do it for you?
You're welcome and good luck!
Ohhh ok ok thanks.. Which performance shop should I order and who answer the phone so I can tell my friend to order it for me.. Thanks alot and I appreciate for u help me..
You're welcome.
tseng1023
Oct 15, 2015 08:30 AM
NismoMaxi02
Oct 4, 2015 09:09 PM
