Resistance numbers for Coils
Anyone know the numbers I should be getting when I measure the resistance for my ingition coils on a 2000 Maxima SE? Also, which cyclinders #1-6 correspond to their location on the block? (i.e. left to right, front to back).
Re: Resistance numbers for Coils
0-ohms is bad, anything greater than 0-ohms is good.
Cylinder #1 is front side closest to passenger side, cylinder #6 is back side closest to passenger side
654
123
Mike.
Re: Re: Resistance numbers for Coils
Originally posted by Max_5gen
You'll be lucky if you have coil shorted so badly that it can be measured by ohmmeter. More accurate test would be measuring inductance because that's what makes sparks. Even one shorted turn brings it almost to zero while ohmmeter won't show any problems. So if you can get hold on inductance meter you could compare your coils and find failed one by low inductance value. Don't know exact range, though.
Mike.
Mike.
go here if you're really interested:
http://et.nmsu.edu/~etti/fall96/elec...ct/induct.html
SHIFT_woosh
Originally posted by woosh
On second thought, just hold the meter for approx 5 secs for a stabilized reading against a good one or all of them. The different reading should be the bad coil.
SHIFT_woosh
SHIFT_woosh
. More realistic approach would be to rent multimeter with ability to measure inductance: failed coil will have inductance in tens times less than the rest of the pack. One can also purchase an extra coil and use it as substitute until failed one found. Time consuming procedure, though. If someone can confirm that failed coils CAN BE detected by ohmmeter because ignition system is powerful enough to burn it completely it would bring some peace to my heart
.Mike.
jmlee44
Oct 2, 2022 02:13 PM
