Drops over 2"
Old Mar 23, 2003 | 07:00 AM
ToasterMax's Avatar
Drops over 2"
are camber plates necessary when cars are dropped over 2 inches such as i have with the Tein S-Tech??
Old Mar 23, 2003 | 12:33 PM
SE7EN's Avatar
Dont worry about camber kit.. Some people say camber kit wont help the tire to not touch the fenderwell.. I used to have camber kit on my Civic and it wont help..
Old Mar 23, 2003 | 01:39 PM
max'n out's Avatar
Camber kit has nothign to do with the fenderwell, it's to adjust the tire to get even wear...I would get it if your stock camber is not allowing for the proper adjustment.
Old Mar 23, 2003 | 07:01 PM
SE7EN's Avatar
I say inside the fenderwell that u can see the tires rubbing.. I know it adjust the camber area to prevent the tire wear out.. I know that..
Old Mar 23, 2003 | 10:09 PM
02'maxed-out's Avatar
If your drop goes lower and into your feder wall, then don't get a camber kit. This will make the tires adjust straight and then you'll have the tire actually sitting on the fender, which you don't want. Plus, a negative camber actually is better for turning, just a little not to much.
Old Mar 23, 2003 | 11:40 PM
AzNx2k2xSEXima's Avatar
i have the teins, i doubt u will need a chamber kit...maybe the chamber bolts, i have a little bit a neg. chamber, VERY LITTLE, you can't tell unless you sit and stare for minutes, my tires seem fine right now, its been a little over a 1000 miles so, yea....AND tein didn't recommend any chamber kit either, they DO tell you to cut ur bumpstops, i think it was the bumpstops, well u have to cut something about an inch in the front, i'd say do it...i bottomed out once and didn't like it at all, most of the time is great~
save ur money and get something else
Old Mar 24, 2003 | 02:42 AM
skyjay617's Avatar
what happen if u dont cut them??
Old Mar 24, 2003 | 03:27 AM
ToasterMax's Avatar
Old Mar 24, 2003 | 09:11 AM
max'n out's Avatar
You woun't have enough strut travel and will bottom out alot.
Mar 12, 2020 12:06 AM
jonreidhead
Jan 6, 2016 09:38 AM
Turbonut
46
Oct 21, 2015 08:28 PM
maxima-junky
Oct 7, 2015 06:13 PM
Redfox
Sep 28, 2015 10:41 AM
