Twin turbo
Old Mar 25, 2003 | 04:34 PM
  #81
vqman
Originally posted by andrew3616
So now that everyone is turboing there maximas, wy dont then twin turbo them?
Old Mar 25, 2003 | 04:39 PM
  #82
vqman
Re: Re: Re: Re: Re: Re: Re: Re: Re: Turbos
Originally posted by Jeff92se
In general we agree but you have to have heat or maintain that heat in order to get good exhaust velocity. I don't see how one would not agree with that.
kinda late getting back on this one...
this is a pretty popular thread...
yeah, I guess you need to maintain high exhaust gas temperature...but I don't know how you can get cold exhaust gas temperatures...
it's exhaust gas...it's hot.
how do you get this "bad" cold exhaust gas, I don't think it's even possible...maybe I am just totally lost...happens all the time...really.
-vq
Old Mar 25, 2003 | 04:43 PM
  #83
Jeff92se's Avatar
I'm needing a caw
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Turbos
How come you don't burn your hand when you put in back of the muffler opening? Because it's cooled down considerbly. Try putting your hand on the outlet end of one of the exahust manifolds(if that was easily done)
Hot gases expand(accerlate). Cooling gases contract(slow down).
-vq
Old Mar 25, 2003 | 04:59 PM
  #84
vqman
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Turbos
see, that's were I was lost, I was assuming we were talking about the air coming out of the exhaust manifold...or even closer to RIGHT were it comes out of the chamber...
I can see where it is hotter there, and has alot of travel to cool down by the time it gets to the muffler,
was the other guy (the one I was agreeing with) suggesting that there need be a long distance between the exhaust exit from the chamber to where that gas enters the part of the turbo that does the spooling?
-vq
Old Mar 25, 2003 | 05:21 PM
  #85
E55AMG2's Avatar
Wat
in a twin turbo setup there is two turbos right, but only one intake?. Is it just that one turbo does not provide enough boost so they go double?
There are 2 turbos, and they spool up sequentially. One to eliminate turbo lag at low RPM and the other to keep it running hard at higher RPMs
Old Mar 25, 2003 | 06:05 PM
  #86
SR20DEN's Avatar
VQ Wizard
Hmm.... how I missed this one all day I have no idea.
Anyways.
Old Mar 25, 2003 | 07:34 PM
  #87
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
OMFG!
Old Mar 26, 2003 | 08:53 AM
  #88
Jeff92se's Avatar
I'm needing a caw
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Turbos
No. You want the exhaust to hit the turbine as soon as possible(ie.. before it gets a chance to lose velocity(from distance and cooling)
-vq
Old Mar 26, 2003 | 11:27 AM
  #89
Kojiro_FtT's Avatar
So do you want hot air to come in your intake so it can suck it in faster? No. It's not as simple as hot=fast cool=slow. Hot gas gives more pressure, but it's not uni-directional. Hot exhaust gas equals more back pressure too. Cooler air takes less volume and can flow more freely through the restricted exhaust pipe. So you can see it's not as simple as you state, which is why people sometimes lose power when replacing their exhaust because there are too many factors at play.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
BkGreen97
Apr 2, 2016 05:47 AM
09maxshawn11
Sep 30, 2015 10:28 AM
Keyno McMike
Sep 21, 2015 07:18 AM
