Speaking of Ghetto Air Box
Re: Speaking of Ghetto Air Box
Originally posted by jjames
A recent thread reminded me of this. So, since I had 5 minutes to kill, I just did it to my car. Sounds pretty cool at WOT.
I'm surprised more people don't do this.
yea has somebody done a write up on this yet? cuz if it really does offer more power/better gains or whatever, then ppl will do it...like me
oh yea, and the sound? im gonna assume its not as loud as using franken car but how loud would you say it is?
Re: Re: Speaking of Ghetto Air Box
I used a rotozip to cut the front lip off. If you don't have a rotozip, a hacksaw would work ok.
Originally posted by Y2KSESteve
You did it in 5 minutes? What'd you use to cut it that quick?
Re: Re: Re: Speaking of Ghetto Air Box
Re: Re: Re: Re: Speaking of Ghetto Air Box
I've already done it, got a couple pics on my homepage.
I tried posting a pic from your homepage, but it didn't work.
Re: Re: Re: Re: Re: Speaking of Ghetto Air Box
*** That's how I got the idea.
I'd make a million!! GAB is sweeping the nation!!
Check out this thread where 2k2_6spd gives more details on his GAB.
I still don't understand where the ooglie scoop is in this setup. Can you provide more info on that 2k2_6spd?
http://forums.maxima.org/showthread....5&pagenumber=2
Originally posted by 2K2_6spd
I cut off the bottom of the black tube that protrudes from the factory scoop, and attatched a 3" dryer vent tube from Home depot, and a gutter down spout thingie, that I screwed into the factory splash guard, this rams the air into the box.
Here's another intake setup I'm considering. Check out Larry's post on page two. He uses a giant 9 inch K&N air filter at the end of the accordion piece, removes the baffle and use a crankcase filter.
Yeah, that's probably true. It just seems a little more pronounced around 75. Sounds cool too.
Do you still have the ooglie intake feeding more air in?
Where is your writeup on this? Hard to do? Feel any gains? Noisy? Do I ask a lot of questions?
Yep and soon a cold air tube from the bottom where the stock resonator attached.
Wouldn't that be the best way to do an ooglie cai. Can't you just remove the elbow from the bottom of the scoop that goes into the resonator, and then run a flexible hose to the from of the car?
After looking under the hood, I think most of the write-ups i've seen overcomplicate this mod. I think you could probably remove that elbow without taking anything apart. I also think that once you get the hose attached to the coupler, this is a ten minute swap from regular intake to ooglie cai.
Looks like a piece of cake. Might have to try it. I think the trickiest part is deciding where to attach the hose.
Thats exactly what ill be doing
It would also appear that this intake would be superior to an aftermarket CAI in a few ways as well. The only thing I can think of that this intake is deffiecient in, compared to PR and Injen, is the looks. I would think this intake would eliminate the low end loss of power that some aftermarket cai users complain about, and also the loss of top end that some aftermarket wai users complain about.
Yea its not tough at all. This is by far the easiest intake to install/make/customize.
No, not really. Just pull out the insert, cut of the front lip and put it back in.
There is more to doing this in conjuction with an ooglie cai, but just the GAB is pretty much cutting off the front lip.
Read the whole thread. There's more to it than that.
Ah, I smell what you're cookin'. Not sure how necessary removing the baffle is, but it couldn't hurt.
I guess it's how you define GAB. I was under the impression it included the ooglie and removing the baffle near the accordian piece, in addition to modifying the top of the airbox.
