Dead Maxima, please help
Old Mar 29, 2003 | 08:50 PM
Ryanb126's Avatar
I was driving in my neighborhood today and break torqued, floored my car, and at about 35 mph i heard a loud thunk, the steering wheel and brake tightened, the ses light went on, and my car died. I drive a 2001 maxima gxe auto, and i had recently just put on a place racing cold air intake, and today was the first day it was actually cold outside since i had gotten it (i live in houston). The engine starts perfectly, nothing is blown from what i can tell, but it dies after about 5 seconds. Could this be caused by the intake? And if u have any suggestions on what could have caused it or what the problem may be i'd greatly appreciate it.
Old Mar 30, 2003 | 02:46 PM
jttaylor155
Make sure the filter didnt loosen up. I have a stillen fliter and it didnt line up right at first. It would loosen up and pull out. There are a bunch of sensors before the throtle body and it dies when air comes straight in wtthout a filter. Just tighten up the clamp. I hope it isnt a stillen cause if it is you may have to do more then just tighten it. I had to drill a new hole in the frame for it to stay on.
Old Mar 30, 2003 | 02:54 PM
Wegaman's Avatar
why would u break torque and floor your car in a neighborhood?
Old Mar 30, 2003 | 03:09 PM
E55AMG2's Avatar
Wat
Blown MAF for sure, among other things.
Old Mar 30, 2003 | 03:13 PM
ychuw's Avatar
Hey I am in Houston too. Maybe we can race sometimes!!
Old Mar 30, 2003 | 03:14 PM
trey
i'm sure he meant to say on the HIGHWAY, he brake torqued and floored the car so he could get out of the emergency lane so he could blend into traffic fast.
Old Mar 30, 2003 | 03:38 PM
studman's Avatar
Unplug the connector on the MAF. Then see if the car will start and stay running. The car won't allow you to go above 2400 RPMs, but it should stay started.
Note: It make take 2 or 3 starts after unpluggin the MAF before the car will stay running, but it's not more than 2 or 3.
Old Mar 30, 2003 | 03:49 PM
Ryanb126's Avatar
When we reconnected the MAF that's exactly what it did. I'm getting it towed to nissan tomorrow, any advice on what i should do, or how much this is going to cost to get fixed, and if i'll be able to keep the intake? The car is still under warranty but i'm guessing this isn't going to be covered.
Old Mar 30, 2003 | 03:57 PM
studman's Avatar
If after you connect the MAF, you may need to let the car run for about 5 mins or so. Then drive (the best you can) to a local AutoZone store. Have the SES light reset. Then start the car up. If the SES light comes back on, have them pull the code. Most likely it will be a MAF failure.
You'll have to revert back to stock and visit the dealer for a new MAF if you are still under warranty.
If you're not under warranty, you can buy a new MAF from Courtesy Nissan. They've got the part 22680-AD210 and tell them you are from the .org. It should be around $60-70 plus shipping.
As for the long term fix... don't rev the car when you first install the intake. The ECU takes time (500 miles or so) to adjust to the changing in air/fuel mixtures. During that period, be gentle to the car. If you search by my name and "reset" in the 5th gen forum, then you can find out how to reset the ECU's emissions information, which also contains the air/fuel mixture information.
Slamrod
Apr 10, 2016 05:24 PM
Balkins
Feb 1, 2016 12:45 AM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
