Cleaning the Engine?
Old Apr 2, 2003 | 10:15 AM
SHPatel's Avatar
Hey guys I need to know what parts of the engine I should cover before cleaning it out. Are there any critical components that I should keep absolutely dry? Thanks
Old Apr 2, 2003 | 11:40 AM
255HP_03_SE's Avatar
Re: Cleaning the Engine?
Anything electrical would probably be a good start
R
Old Apr 2, 2003 | 11:49 AM
Y2KSESteve's Avatar
All you'd really need to cover is your intake if you have an aftermarket one. The rest of your engine should be fine. CD2 engine detailer works great for cleaning your engine as well.
Old Apr 2, 2003 | 11:50 AM
NT2SHBBY
that gunk stuff works good too!
Old Apr 2, 2003 | 03:11 PM
woosh's Avatar
Will CD2 do damage to the hose or belts if any gets on it? Is gunk safe for the belts/hoses?
SHIFT_woosh
Old Apr 2, 2003 | 03:22 PM
Y2KSESteve's Avatar
SHIFT_woosh
I spray CD2 over my entire engine and it makes everything look good. Simple green is good for areas that have a lot of grease or oil.
Old Apr 3, 2003 | 07:10 AM
SHPatel's Avatar
Do you use a high pressure washer to wash everything away?
Old Apr 3, 2003 | 10:14 AM
NO!!!
Old Apr 3, 2003 | 10:46 AM
SHPatel's Avatar
Originally posted by 255HP_03_SE
NO!!!
What should I use?
Old Apr 3, 2003 | 11:12 AM
karguy's Avatar
What should I use?
I do mine at home using Simple Green as it is biodegradable and doesn't hurt grass and plants. I use a high pressure spray with minimal water volume to rinse everything off. I have a brass hose nozzle that I adjust manually to get the desired spray pattern. The Simple Green is effective, cheap (big spray bottle is under $4 at Walmart) and has a pleasant odor! Hope this helps!
Old Apr 3, 2003 | 11:58 AM
CVicVogel's Avatar
SHIFT_woosh
years ago, the original GUNK would put pinholes in rubber hoses. Use it ONLY on the bottom of the metal block! Since some blocks are alumium, be extra careful.
thanks
Vic
derekinthez
Nov 13, 2022 04:00 PM
6spd4dsc
Mar 4, 2016 05:19 PM
Maximan190
Dec 16, 2015 06:01 AM
fastcarny
Oct 6, 2015 10:42 AM
03VQMAX
Sep 5, 2015 03:47 PM
