Any Pics Of H & R Springs?
Old Apr 8, 2003 | 05:08 PM
2k3silvermax's Avatar
Anyone have pics of their max after installing H & R springs?
Old Apr 9, 2003 | 07:27 AM
ABS's Avatar
ABS
bump
Old Apr 9, 2003 | 07:36 AM
asu174's Avatar
Clay Aiken has fancy genitals
http://maxima.cardomain.com/id/michaelae
http://maxima.cardomain.com/id/perrymax
Old Apr 9, 2003 | 07:46 AM
NT2SHBBY
is it me or does the H&R really not provide that much a drop??
2k2nyc's car with the same spring/strut setup proved much lower...
Old Apr 9, 2003 | 08:11 AM
asu174's Avatar
Old Apr 9, 2003 | 08:47 AM
GaMax97GLE's Avatar
I like the rear H&R drop, but the front could be a little lower. But these springs ride great and are comfortable.
Old Apr 9, 2003 | 08:48 AM
T-bone's Avatar
I have H&R and no they don't provide a big drop. The ride, however, is soooooooo much better than stock
Old Apr 9, 2003 | 09:06 AM
KTM's Avatar
KTM
Did you keep the stock struts/shocks, or swamp them out for something else?
Old Apr 9, 2003 | 09:08 AM
Maxman2000's Avatar
For me the H & R springs are to high or it could be because the guy had small rims. I'm planin on Eibach.
Old Apr 9, 2003 | 09:17 AM
ABS's Avatar
ABS
Everyone, thanks for posting these links. For whatever reason, my car is sitting lower on the H&R/Tokico setup than what I am seeing here. Is it possible that the H&R springs sag after a while? On the rear the "finger gap" test allows only one of my fingers in the gap between the body of the car and the OEM rim with 235/45 Dunlop tires.
Any thoughts?
Old Apr 9, 2003 | 09:20 AM
T-bone's Avatar
I have H&R with Tokico Blues. The stock struts cannot handle the greater compression generated by an aftermarket spring.
Old Apr 9, 2003 | 10:05 AM
GaMax97GLE's Avatar
I kept the stock struts for now. They work for everyday driving. When they start to go, I will replace with AGX.
Old Apr 9, 2003 | 11:43 AM
Matthew's Avatar
Nice Rims, they look tight w/ kit and tint, and no spoiler. What kind are they???
Old Apr 9, 2003 | 11:51 AM
NT2SHBBY
hey Matt...a little OT, but how much Synthetic ATF do you need for the auto tranny?? also what struts are you on with the H&Rs?
Old Apr 9, 2003 | 12:19 PM
Matthew's Avatar
...To do a full flush and fill at a lube service place, where they remove ALL your old fluid (this is what I did) you will need 12 quarts of synthetic.
If you just drain and fill, you need maybe 5 or 6 quarts. Obviously the full flush will give better results, your choice.
The H&R's are still on stock struts/shocks have been for a year now. Still rides pretty good. I will probably get Toks Blues eventually.
Old Apr 9, 2003 | 12:22 PM
NT2SHBBY
thanx a lot dude!!!!!!!!!!
Old Apr 9, 2003 | 03:38 PM
MaxDoogie's Avatar
I'm riding on H & R's and I am unhappy with the front drop, rear could use work but is better...I have had mine for over a year now and no, they have not settled at all...I am running stock struts, too...I do love the ride though
Tein springs, here I come!
Old Apr 9, 2003 | 05:55 PM
ItalianMax2kSE's Avatar
Go with MAXSPEEDS! They are cheep, they are made by the same people that make H&R, and the drop is really nice. I used to be able to sick my whole hand in the front of my wheel well, now I can barley fit 1 finger! AND The drop is even in the front and back.
Old Apr 9, 2003 | 06:56 PM
02'maxed-out's Avatar
I say go with the TEins... JAP spec springs... how could you go wrong??? you can't... and Tein is the shieet when it comes to suspension...
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
