FSTB/RSB & wheel alignment
Old Apr 13, 2003 | 04:31 PM
RC03MAX's Avatar
I have to get my wheel alignment checked because I recently hit a deep pothole which bent my rim. I have a Stillen FSTB & RSB.
Should I remove these prior to having the wheels aligned?
Thanks for your help.
Old Apr 13, 2003 | 04:41 PM
mjg's Avatar
mjg
they will charge you more to remove the crap and put it on, so the answer is yes.
Old Apr 13, 2003 | 06:09 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Re: FSTB/RSB & wheel alignment
umm, these mods dont affect alignment at all. you dont have to remove them. if you messed up your struts then you might want to remove the fstb so they can remove the old strut but i wouldnt even go that far. neither the fstb or rsb will get in the way or affect alignment. they could affect handling if you only had one side of the rsb or fstb bolted down but you should be good to go.
Old Apr 13, 2003 | 07:08 PM
RC03MAX's Avatar
Re: Re: FSTB/RSB & wheel alignment
thanks for the info...I kinda thought that was the case but I wasn't 100% sure.....hopefully the dealership won't give me a hard time...
the car seems to drive straight but I wanted to be sure by getting it checked anyway
Old Apr 13, 2003 | 07:27 PM
sloppymax's Avatar
Re: Re: Re: FSTB/RSB & wheel alignment
10-4. im going in to get a strut replaced under warranty and im having the alignment done at the dealer from now on. my girlfriend popped one my michelins and i took it firestone to have the alignment done. i had a lifetime contract but i dont think im going back. the dealer is the only one around here that has a method for adjusting caster which firestone says cannot be adjusted.
Fbana41
Aug 29, 2016 12:18 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Andy29
Sep 29, 2015 05:32 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Redfox
Sep 28, 2015 10:41 AM
