i htink im experiencing the cattman flex problem
Old Apr 14, 2003 | 09:28 PM
klee215's Avatar
hey, i purchased my cattman y-pipe right before the "flex problem". i have had no problems, until recently I started noticing the bees in the can sound from the flex section is really loud and i feel a lil power loss too. Anyway to find out if thats the flex section problem without taking off the y- pipe???????????
Old Apr 14, 2003 | 09:32 PM
maxcosity's Avatar
I think you have to unflex it to see, so I would guess that requires removal of the y-pipe..
take it to a muffler shop (midas or some ****) - ask them for a free inspection.. (they do this ya know)
then decide what to do about fixing it and maybe ask them how much to swap that for another pipe... (no more than $50 I'd think to jack it up, swap pipes, and drop it down - simple 30 minute job)
Good luck!
Old Apr 14, 2003 | 09:41 PM
Vadim's Avatar
50 bucks? You wish, man! I had a 94 Altima with a hole in the flex section, I took it to Midas and they wanted $160 to swap it out with a new one. Flex section itself was 60 bucks. Sux!
Good luck!
Old Apr 14, 2003 | 10:16 PM
2kGLE's Avatar
Re: i htink im experiencing the cattman flex problem
You do not need to remove the ypipe to inspect the flex, just drop the cat and take a look with a flashlight (and maybe a mirror). I read a bunch about this before buying my budget y. I assume youve seen pics and know what you are looking for.
Old Apr 14, 2003 | 10:57 PM
klee215's Avatar
yeah the flex section is supposed to look clogged, right?? or just smaller in diameter..
Old Apr 14, 2003 | 11:19 PM
2kGLE's Avatar
Maybe someone can search and link you to a pic, but its pretty obvious if you have a flex problem. It will look all collapsed inside. I remember seeing one where the passage was shrunk down to about the size of a grape.
Old Apr 14, 2003 | 11:45 PM
Y2KSESteve's Avatar
Thats what it should look like. I'll try and find a pic of it...
Old Apr 14, 2003 | 11:52 PM
Y2KSESteve's Avatar
Pic of the inside flex section breaking down...
Old Apr 15, 2003 | 07:24 AM
[maxi-overdose]'s Avatar
more pics
http://www.boostedmaximas.com/y2kevs..._flex_section/
credit: Y2KevSe
Old Apr 15, 2003 | 07:32 AM
y2kse's Avatar
Re: Re: i htink im experiencing the cattman flex problem
You do not need to remove the ypipe to inspect the flex, just drop the cat and take a look with a flashlight.
Old Apr 15, 2003 | 07:55 AM
maxcosity's Avatar
I was saying $50 for labor but you should go buy your Y-pipe elsewhere, they (Midas, etc...) will just rip you off!
Old Apr 15, 2003 | 09:44 AM
Shift_VQ's Avatar
Is this pretty common on the cattman y pipes because I want one but now im not so sure. Does the stillen y pipe do this flex thing?
Old Apr 15, 2003 | 11:18 AM
Kevin had a stillen Y-pipe....there is another case of stillen flex section went south.
I think both Stillen and Cattman switched from mesh-wired flex to another type of flex which is supoorted by a set of rings.
Old Apr 15, 2003 | 10:25 PM
klee215's Avatar
thanks y2ksesteve for the pics..and YES just talked to Midas and they said aprrox. 125 bucks to fix flex section..Damn ripoff
Old Apr 15, 2003 | 10:34 PM
2kGLE's Avatar
Don't go to midas, find a muffler shop. I'm sure you can find a muffler shop that will do it for cheap. Did you confirm you have the flex problem?
Old Apr 15, 2003 | 10:54 PM
klee215's Avatar
not yet just trying to find out how much money its going to cost if i do.but wit my luck i prob do have the flex prob
Old Apr 16, 2003 | 01:44 PM
DOM's Avatar
DOM
So when did this newer and improved flex section start going into the Y pipes?
knight_yyz
Nov 6, 2015 02:34 PM
knight_yyz
Oct 24, 2015 08:05 AM
RWCreative
Sep 21, 2015 11:01 AM
