Need How-to for changing drive belts
Old Apr 20, 2003 | 11:07 AM
ynot411's Avatar
Has anyone done or found a "how to" for chaning the drive belts for the 2k2?
Old Apr 20, 2003 | 11:08 AM
jjs's Avatar
jjs
Re: Need How-to for changing drive belts
Why on earth do you need to change them already?
Old Apr 20, 2003 | 11:18 AM
ynot411's Avatar
Re: Re: Need How-to for changing drive belts
Currently at 40,000+ miles. Good enough reason?
Old Apr 20, 2003 | 11:50 AM
Larry's Avatar
Here are some instructions I wrote when installing my ASP underdrive pulley.
1. If a lift if not available jack car up sufficiently to perform work under car. Use jack stands for safety.
2. Remove front passenger wheel and tire.
3. Remove passenger side plastic splash guard for easy access to pulley.
4. Loosen 12 mm locking bolt on power steering adjuster. Head of bolt is facing toward inner fender well, perpendicular to adjuster bolt and just to the rear of power steering pulley. Access to this bolt is best from under car.
5. Loosen 14 mm power steering pump rotator bolt on engine side of pump. It is accessible behind rear precat with a swivel or series of swivels and long extension from center of vehicle. The oil line to the oil filter is directly in line with this bolt.
6. Turn 12 mm adjuster bolt clockwise, as in tightening, to loosen belt. This bolt faces towards the ground and is located on bottom of adjuster. Use a long extension and swivel for access.
7. Loosen 14 mm ac/alternator tensioner pulley bolt. This bolt is in the center of the pulley and holds the pulley to the tensioner bracket. With bolt loose tensioner pulley is free to slide up and down on bracket within the limits of the 14 mm adjuster hex bolt. Turn 14 mm adjuster bolt counter clockwise to loosen belt and clockwise to tighten.
8. With both tensioners in the loose belt position, remove both belts.
9. Use a pneumatic impact wrench remove 19 mm center bolt holding crank pulley to shaft. Pulley is free to remove.
10. Use motor oil to lubricate ASP underdrive crank pulley seal ring on pulley hub. This insures lubrication to the crank seal when installed. Install pulley by hand locating keyway groove to key. Insure that pulley bottoms out on the crank shaft.
11. Reinstall crank bolt and torque to 140 ft/lbs. Locktite 242 thread sealer is recommended on threads.
12. For ease of belt installation, adjust both belt tensioners to insure plenty of free play to belt. Install Gates belt part number K040292 (or equivalent) on power steering and K060408 on ac/alternator. Insure both belts are properly positioned in grooves in all pulleys.
(I'm guessing on this one, I just tighten it until it felt right to me. Might have to refer to shop manual for belt tightening)
13. Tighten belts until belt has 1/4" movement at center of belt. Do not over tighten. Remember the power steering pump 12 mm bolt turns counter clockwise, as in loosening, to tighten belt.
14. Reinstall splash guard and wheel.
Old Apr 20, 2003 | 07:29 PM
ynot411's Avatar
Thanks so much Larry. You're a life saver. I'll perform the operation tomorrow and let you know how it went. I'm trying to fix the loud start-up that I'm hearing when the car is started from "cold". I was thinking that the pullys arent torqued right or something. But I'll see after tomorrow if I can correct the problem. Thanx again.
tsi6001
Oct 3, 2022 10:23 PM
kjlouis
Nov 24, 2018 06:09 AM
Slamrod
Apr 10, 2016 05:24 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
RealityCheck
Aug 5, 2015 06:18 AM
