Transmission Shifting in and out of OD at highway speeds.
Old Jan 21, 2001 | 03:16 PM
edadams's Avatar
Has anyone noticed problems with their transmission acting funny at cruising speeds on the highway. My 2000 max se auto will shift in and out of overdrive while traveling at 65 to 80 mph. the dealer performed the tsb on the transmission, that fixed all 1st,2nd,3rd gear delayed shifting problems. the car shifts very firmly now which i like. the dealer says now they must either replace the transmission, or keep it for a few days to try and isolate the problem. Anyone have any advice?
Old Jan 21, 2001 | 03:37 PM
Loe max's Avatar
If you have your foot on the accelerator, its normal. If not, then have it checked out. You maybe just used to the old slushy TCM and not use to the new one. At what mile(s) did you get the new TCM installed? I just experienced my first slipping yesterday, only the transmission was in 4th gear, in stop-and-go traffic. My car has about 13,000miles and I fear getting a new TCM will only make the transmission worse.
Question- If the transmission goes, It will be under warrenty right?
Old Jan 21, 2001 | 03:41 PM
edadams's Avatar
The dealer did not replace the TCM, just the valves in the trans. Do they need to replace the tcm as well?
Old Jan 21, 2001 | 03:46 PM
edadams's Avatar
My car has 13200 miles. The trans never slips since the new valves or solenoid was replaced. I drove the **it out of my 95 maxima and put well over 170k hard miles on the A/T without any problems. That car was raced in scca events and generally abused. This is begening to worry me. I guess I'll trade cars according to the amount of time left on the warranty,
Old Jan 21, 2001 | 09:09 PM
mdeal's Avatar
When you say shifting in and out of overdrive, do you mean it downshifts then upshifts, or do you mean the OD button on the dash keeps going on and off, with the RPM's increasing/decreasing depending on the state of the OD button?
Old Jan 22, 2001 | 09:52 AM
kpark's Avatar
Hey edadams I experience the extact problems you mentioned. It all started after I got the new TCM. When crusing at the same speed or even just accelerating slightly, the trans will downshift and then pop right back to 4th. It's quite irritating. The trans acts like it's confused or just plain broken.
Old Jan 22, 2001 | 10:18 AM
acMAX's Avatar
hmmm......
sounds like you have a f*cked up transmission. You should bring it back to the dealer.
Old Jan 22, 2001 | 03:50 PM
edadams's Avatar
The Car does this on the highway only. At steady throttle around 65 - 80 mph. It even does it with the cruise on. I wonder if it could be a Throttle position Sensor?
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
Andy29
Sep 29, 2015 05:32 AM
