Is check engine light covered under wtty?
Old May 1, 2003 | 05:34 AM
Y2KMaxGXE-R's Avatar
Is it covered under the 5yr/60K mile powertrain wtty? Can anything other than powertrain trigger the check engine light?
Service advisor said that it will be known after the code is pulled if it is covered. Dunnow if he was just cautious or trying to give me BS.
Old May 1, 2003 | 06:00 AM
jttaylor155
It does depend on what it is. Mine came on because both my oxygen sensors went bad. It cost me $100 each time. I'm pretty sure that there are very few reasons that will be covered.
Old May 1, 2003 | 06:33 AM
Igor911's Avatar
Re: Is check engine light covered under wtty?
I told you yesturday Mr. Know-it-all
YES IT IS!
Old May 1, 2003 | 06:38 AM
][ 35's Avatar
yup it all depends on why the CEL is on.
I had the CEL so i took it in for service after they hooked it up they asked me was the sit ever taken out. and being dumb that i'm i told them when i installed some audio parts on the car i took the sit out to install some wires and i had the key in the ignition... blah blah... i told them everything... don't know what i was thinking...
anyway... since i caused the CEL to come on i had to pay to have it reset
Old May 1, 2003 | 06:49 AM
255HP_03_SE's Avatar
The CEL is the vehicle's way of letting you know something is wrong... when it comes on the code could be anything from the engine to the tranny to an O2 sensor.
-R
Old May 1, 2003 | 06:54 AM
Cutler's Avatar
It is something emissions related, usually o2 sensor gone bad...
Old May 1, 2003 | 07:12 AM
or a coil pack... or damage to the vacuum canister underneath the car in the rear driver's side... etc.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
BassAddictJ
Aug 4, 2015 11:38 AM
