Camber Adjustment
Camber Adjustment on TEIN? HELP!!!!!!!!!!!!!!!
I just replaced my set-up from H&R/Tokico blues to Tein/KYB Gr-2. When I took the tires off to replace it with Tein/KYB, I notice that inside of my tires were wearing off much faster than the outer. Now, I did not have alignment done on the H&R/Tokico setup. But, I am going to get camber plate for the fronts to adjust.
I was wondering, what about the back.
1) Can alignment be done on the back suspension, since it is a beam instead of IRS.
2) If so will alignment fix the problem or do I need to get camber plates/bolts for the rear.
What have you guys done, I am sure many of you had the same problem.
Please help....
Please help....
hmm.. i dont know! I have the same Tein/GR2s, but i was holding off on an alignment becuase my car tracks BETTER now than with the stock suspension!
i know the front camber is adjustable, but the rear i dont think is. Take it to an alignment place and see what they say...
BTW, please share your thoughts on how much better the Tein/GR2 combo is better than the H&R/Tocrapos. Many people want to hear! Not to mention the drop!
i know the front camber is adjustable, but the rear i dont think is. Take it to an alignment place and see what they say...BTW, please share your thoughts on how much better the Tein/GR2 combo is better than the H&R/Tocrapos. Many people want to hear! Not to mention the drop!
Using stock parts, neither the front nor the rear suspension is adjustable. With aftermarket parts, you will be able to adjust the front but not the rear. I just had my car aligned (since I lowered it) and the camber was still in spec. I am running KYB GR2 and H&R. Good luck.
Re: Camber Adjustment on TEIN? HELP!!!!!!!!!!!!!!!
There is no adjustments possible in the rear of the car. The beam setup will not go out of alignment when you lower it.
Do you know exactly what he did in the rear? I just went out and searched under the car and couldn't find any adjustment points. It's just two wheels setting on a live beam axle. Ride height, in no way, should affect the alignment in the rear.
Originally posted by NT2SHBBY
with my maxspeed/gr-2 combo, the mechanic did a full 4 wheel alignment so yes the backs can be done and IMO should be
my camber looks great all around
tarun900
19
Dec 20, 2021 06:57 PM
Apr 16, 2020 05:15 AM
