how to remove small scratches?
Old May 18, 2003 | 06:47 AM
joeyd's Avatar
from car washes/ highway's...all on the side of my black max a million small scratches...what is the best cleaner/polish..what do i need to get rid of them?
Old May 18, 2003 | 07:18 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
Re: how to remove small scratches?
Whatever you do, don't use 80 grit sandpaper.
Old May 18, 2003 | 07:21 AM
wcasskicker's Avatar
Polish first, put 3 layer of wax....then you will be fine.
I use Sonax polish and wax.
Old May 18, 2003 | 09:13 AM
WizzaMax's Avatar
and by NO means use a power sander...or try to blend it in by sanding the whole car....
Old May 18, 2003 | 05:00 PM
WHEELMAN_03_SE's Avatar
i use finish first wash and conditioner and then use finish first clearcoat safe polish it works woners after you get a few layers built up and then it makes the car a lot easier to wash because dirt doesnt stick near as much, also avoid any wash/polishing cloths that are anything but 100% cotton because anything other than cotton especially nylons and synthetics will put those swirl marks in your car
Old May 18, 2003 | 05:58 PM
limsandy's Avatar
Here is how you do it:
1) wash your car
2) use meguiar's scratch-X
3) use meguiar's car wax to finish up
~limsndy
Old May 18, 2003 | 07:29 PM
Maximax2's Avatar
Re: Re: how to remove small scratches?
1) wash your car
~limsndy
I do the same, except that I'm not a big Meguiar's wax fan (do use Scratch-X though). I use Zymol wax (the cheap kind at Wal-Mart). After doing some research, Zymol wax came out really high, and the cheap version is just about as good as their really expensive wax.
The "washing your car" sticky has some good info.
Old May 18, 2003 | 09:03 PM
scopium
try Scratch X. it will remove most of your small scratches for sure,, then wax
Old May 18, 2003 | 09:13 PM
FUEL
Scratch X will not remove that stuff. If you want to get rid of them you will need to use a rotary. If you want to hide them and partically remove them you will need a porter cable and some 3M or Megs compounding material and work them out. If you want more detail e-mail me.
bigdogsteve
Jan 31, 2018 04:18 PM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
