IACV Help - Location & Adjustment
Old May 19, 2003 | 08:35 AM
Stikya's Avatar
Ok, I've searched, and seen it talked about and danced around. But, I can't find anything definitive on it.
1) Where exactly is the IACV (Idle Air Control Valve) located?
2) And can you do anything to it, to adjust your idle up?
I need my car to idle a little higher!
Old Jul 9, 2003 | 06:05 AM
MercerMax's Avatar
I have the same problem. Been searching and can find nothing definite. Also, what does TPS stand for?? Throttle Position Sensor?? Where is this?? Thanks.
Old Jul 9, 2003 | 08:33 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Re: IACV Help - Location & Adjustment
ill have to look in my haynes for the location of the IACV but i was told the only to adjust idle was with the consult 2. i had mine bumped up to keep the udp from ticking when it was spinning to slow underload.
Old Jul 9, 2003 | 10:45 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
You only adjust the idle with a Consult-II.
I believe there is a screw somewhere that is factory set for the idle mixture, but I don't think you want to mess with that to up the idle.
tarun900
19
Dec 20, 2021 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
leatherneck
Sep 30, 2015 09:16 PM
