My neighbor is an Infinity Tech
Old May 30, 2003 | 10:23 AM
MAXIMUS95GST's Avatar
My neighbor is bringing home the Consult 2 to advance my timing on my 2003 SE Maxima. He's a very cool guy. He was talking highly aobut the Maxima, that they are good cars etc... Now my question is what other options can he enable for me...
Thanks Guys.
Old May 30, 2003 | 10:26 AM
jjs's Avatar
jjs
Re: My neighbor is an Infinity Tech
Thanks Guys.
If he is a tech, wouldn't he know what he can do for you? Have you asked him?
Old May 30, 2003 | 10:35 AM
[maxi-overdose]'s Avatar
Thanks Guys.
depends on what tools does he have. so....I doubt he will be able to do wheel alignment for you
regular oil change, tranny service, cooling system, belts, PCV, ignition stuff, etc. etc....if he has the tools and loves his job.
or you can borrow his FSM and do it yourself.
Old May 30, 2003 | 10:57 AM
hokiemax's Avatar
Re: Re: My neighbor is an Infinity Tech
I think he was asking what other options can the infinity tech "enable" on the ECU, if there are any. I dont think the tech would want to come home from a full day's work and do oil changes and change belts unless you paid him 1000 bucks !
Old May 30, 2003 | 12:11 PM
maximamaybe's Avatar
There are several you can do. These were from altimas.net. I did a couple on mine.
After reading a couple of threads about adjusting the sensitivity of the automatic on/off feature for my Xenons, I decided to pay a visit to my dealer. Well, it turns out that once the car is hooked up to the dealer’s diagnostic computer, they can change several other settings at the same time.
My dealer (Trophy Nissan, Mesquite TX – also the operator of www.nissanwholesaleparts.com) told me that these settings are not listed in the owner’s manual, or even in the books the repair guys use. He says the only reason they know about the settings is from a training course they had to take before the 2002 Altima came out. They even made their own worksheet so Trophy’s customers can fill it out before their car is hooked up to the computer. Here are the settings you can change and the appropriate modes:
Door Lock/Unlock (with single click on keyfob)
Mode 1: Unlock left front door only
Mode 2: Unlock all doors
Anti-lock Out (prevents locking keys in car)
Mode 1: Master door lock switch can activate door locks w/ key in ignition
Mode 2: Master door lock switch cannot activate door locks w/ key in ignition
Dome Lamp Timer
Mode 1: Interior lamp comes on when left front door is unlocked
Mode 2: Interior lamp does not come on when left front door is unlocked
Retained Power (Amount of time windows and sunroof will operate after turning off ignition)
Mode 1: 45 seconds
Mode 2: No delay (Will not operate after ignition key is turned off)
Mode 3: 2 minutes
Auto Light On (headlights turn on as it gets dark)
Mode 1: Factory setting
Mode 2: Lights come on sooner than factory setting
Mode 3: Lights come on later than factor setting
Mode 4: Lights come on later than Mode 3
Head Lamp Battery Saver (applies when headlights left in “on” position, not in “auto.”
Mode 1: Shuts lamps off after 5 minutes
Mode 2: No time delay (headlights turn off immediately)
Headlamp Illumination delay (time headlights remain on after exiting car when headlight is in the “auto” position)
Mode 1: 45 seconds
Mode 2: No Delay (lights turn off immediately)
Mode 3: 30 Seconds
Mode 4: 1 minute
Mode 5: 1 ½ minutes
Mode 6: 2 minutes
Mode 7: 2 ½ minutes
Mode 8: 3 minutes
Hazard and Horn Reminder Mode (key fob allows you to choose between modes 1 & 2, but there are 4 others)
Mode 1 (C Mode): Lock = 2 flash, 1 horn /// Unlock = 1 flash, 0 horn
Mode 2 (S Mode): Lock = 2 flash, 0 horn /// Unlock = 0 flash, 0 horn
Mode 3: Lock = 0 flash, 0 horn /// Unlock = 0 flash, 0 horn
Mode 4: Lock = 2 flash, 0 horn /// Unlock = 1 flash, 0 horn
Mode 5: Lock = 2 flash, 1 horn /// Unlock = 0 flash, 0 horn
Mode 6: Lock = 0 flash, 1 horn /// Unlock = 1 flash, 0 horn
Remote Auto Locking Function Mode (Doors automatically lock after exiting car)
Mode 1: 5 minute delay
Mode 2: Function disabled
Mode 3: 1 minute delay
Remote Panic Alarm Operation Mode (activates when button on keyfob held for approx. __)
Mode 1: .5 seconds
Mode 3: 1.5 seconds
Remote Trunk Open Operation Mode (activates when button on keyfob held for approx. __)
Mode 1: .5 seconds
Mode 3: 1.5 seconds
Remote Power Window Down Operation Mode (activates when button on keyfob held for approx. __)
Mode 1: 3 seconds
Mode 3: 5 seconds
Old May 30, 2003 | 12:52 PM
JdoubleOe703's Avatar
teddibear703
how do you do the headlamp illumination delay? I would love that on my car, for 30 secondes....
Old May 30, 2003 | 01:03 PM
Don't remember the exact method, but it is all in the menu system in the consult. t56gen3 and I just started messing around until we found it. The menus are labeled similar to the function
Old May 30, 2003 | 01:17 PM
MONTE 01&97 SE's Avatar
I agree because they come on instantly when I go in and out of the garage during the day and the manual clearly says that frequent on/off of the HID's lower their life expectancy. HID's are expensive to replace I want to know on this one as well.
litch
123
Jan 4, 2024 07:01 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Redfox
Sep 28, 2015 10:41 AM
REDinLV
Sep 28, 2015 12:31 AM
